Old 04-09-2008, 01:31 PM   #1 (permalink)
Default Need A New DVD Writer...
Hi Everyone,
I want to buy a DVD writer. Could you guys please help me out at some good ones available in the market. Budget below Rs. 2000. Thanks.
hell_storm2006 is offline
Old 05-09-2008, 06:49 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Need A New DVD Writer...
Anything except sony.
dheeraj_kumar is offline
Old 05-09-2008, 06:55 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Sony/Samsung will be good.
few Liteon models too.
These days, how a dvd writer works purely depends on your luck and nothing else
some say sony is good some say samsung. In the end, it's your luck
desiibond is offline
Old 05-09-2008, 07:41 PM   #4 (permalink)
True, but keep in mind that the NEC/Optiarc hardware which the Sony writers use is extremely pathetic and prone to failure.
Old 05-09-2008, 09:26 PM   #5 (permalink)
Violent serenity.
Psychosocial's Avatar
^^I am using Optiarc since 10-11 months and it has served me well......but it can be luck .
As of now, stick to LiteOn. LiteOn LiteScribe LH20A1P is a nice and reliable drive.
Psychosocial is offline
Old 05-09-2008, 10:47 PM   #6 (permalink)
Ethan_Hunt's Avatar
I have owned the LH20A1P drive & it recently went dead.But not before burning over 300 odd DVD's over a year.I would say it made my moneys worth.The only downside is it's noisy as hell.If you can bear that then no issues.I got myself a Samsung SH-S223F after much research.Absolutely silent drive & is performing pretty similar to my earlier Lite-On.
Are you sure LH20A1P has LiteScribe? AFAIK it didn't when I had it.Did you mean the LH-20A1H?
V for Vendetta
Ethan_Hunt is offline
DVD writer damn slow..I got IMATION dvd writer.. roonie Hardware Q&A 9 09-01-2008 08:05 PM
got a new dvd writer Samsung Super WriteMaster 18x DVD Writer xbonez Hardware Q&A 7 14-08-2007 02:10 PM
DVD Writer not available vineetrocks2005 Hardware Q&A 1 27-04-2007 02:16 AM
dvd writer bholu Hardware Q&A 4 24-02-2006 09:58 PM
need 2 buy a dvd writer The Day Walker! QnA (read only) 1 09-06-2005 11:01 AM
