Old 03-09-2008, 09:17 PM   #1 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Lets discuss our newly bought ATi Radeon HD 4850 here
I will be the first to post
well...i have bought the new pcb( with cooler) Palit Radeon HD4850 512MB GDDR3.....at about 10.4k all from Tirupati Enterprises Kolkata.
PICS UPDATED:
1.The Pack
2.Front
3.Angled view-from left
4.The back
5.View of the cooler
6.Side view-right
Heres a few pics from GPUZ v0.2.7
Heres the basic Info screen
See the new bios version? Its the newest 11.07 released on 30th July,2008!
The result? Just scroll to the pic below!
Heres the monitor screen after 10mins at idle......
Yesss!!!! The beast idling at 46 degrees centigrade!!!! WOW!!!!! Thats some improvement!!!
Well,the fan speed(RPM) is '1' : Ridiculous as it may seem,its because the fan has only 2 connectors! But have a look at the fan speed(%),6%. Now,thats real silent!
Below is the details of the fan routine:
Temp Fan Speed
(in C)
<60 -6%
60 -14%
65 -22%
70 -31%
75 -40%
80 -48%
85 -59%
90 -71%
98 -100%
Others:
PWM Mode-3
PWM Hysteresis-0
PWM Ramp on-0
PWM Ramp-0
Duty cycle 100%-135
Duty cycle min-5
Spinup cycle-48
Spinup time-2
T_min-15
T_max-105
T_slope-37
T_hysteresis-4
Heres a 3dmark 2006 v1.1(Feb 08 Hotfix applied) run report.....
EDITED
Thats 9379 3dmarks(forgive my CPU ) wid HDR/SM3.0 score of 4921 and SM2.0 score of 4237!
Now thats cool!
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 03-09-2008, 09:47 PM   #2 (permalink)
Default Re: Lets discuss our newly bought ATi Radeon HD 4850 here
wow thats really tempting ...post some gaming pics with all settings high ...it will be a treat to see how the pics looks
also which driver and operating system u are using ??
chilling.....
imgame2 is offline
Old 03-09-2008, 10:04 PM   #3 (permalink)
mukherjee's Avatar
well am using Windows XP Professional with SP2 installed(32 bit).
And using Catalyst v8.8 driver suite.
Old 03-09-2008, 10:37 PM   #4 (permalink)
G.A.M.E.R
Shloeb's Avatar
Should have waited for this. Mine idles at 57 degrees at 65% fan speed!!!!!!!!!!!!!! Bought at a lot higher price of almost 12k after a few days it released from itwares.com.
Mine scores 12094 with everything at stock.
Core2Duo E7200 @ 3.16 Ghz| ABIT IP35-E | 2GB Transcend 800Mhz | GeCube ATI HD 4850 | 250 GB Western Digital | Corsair VX450W
Dell Studio 1558
Shloeb is offline
Old 03-09-2008, 10:42 PM   #5 (permalink)
fan fix doesn't work for u ...??
chilling.....
imgame2 is offline
Old 03-09-2008, 10:43 PM   #6 (permalink)
G.A.M.E.R
Shloeb's Avatar
Is their any way that i can flash my 4850 with the newer BIOS? Is it available for download?
Dell Studio 1558
Shloeb is offline
Old 03-09-2008, 10:47 PM   #7 (permalink)
yes u can flash bios but its risky ...so follow very carefully ...the steps ...
i suggest u USE bretware's bios on guru3d it works for many people ...
chilling.....
imgame2 is offline
Old 03-09-2008, 10:59 PM   #8 (permalink)
mukherjee's Avatar
have a look at the techpowerup forums and learn about their RBE(Radeon Bios Editor) tool....it might help
hey buddy!
plz post the breakup of ur 3dmark score plz! all the SM2.0/HDR+SM3.0 stuff !!!
Old 03-09-2008, 11:06 PM   #9 (permalink)
hey buddy!
yes one should break up the 3D mark scores ...pata nahin 3d mark CPU aur 10 cheezon ka score kyon include kar leta hai ....
chilling.....
imgame2 is offline
Old 03-09-2008, 11:11 PM   #10 (permalink)
mukherjee's Avatar
+123456789
thanx for support bro!!!!
btw,when r u getting ur card?
i think i will be geting my dell monitor within this week.....with all my limitations(and requirements),what is ur opinion abt my choice of lcd?
Did u see the pics?
UPDATE:
Heres the temp after 10mins of Atitool action with 'Show 3d view' enabled
Thats an amazing temp! 68 degrees centigrade!!! 8)
Old 03-09-2008, 11:24 PM   #11 (permalink)
oh i will be getting my card by this week-end tomo i have to hunt for the lowest prices i can get for the card in my place ....and with ur budget i think i would have chosen the same monitor its good enough ....cos dell warranty is just awesome and its worth every penny u spend and its the best 19" out there ..
+ i don't know about the RTC error and all ...but u don't have much choices ...so i think its best for u ...and i m sure... u will be blown away ..specially since u will going from CRT to LCD ...u will love every bit of it once u get it ....and within a week u will forget any shortcoming people talk of !!
plus i saw the pics and m very glad that there is no need for even fan tweak ...
but do post some eye candy pics from some game i would love to see it ...
chilling.....
imgame2 is offline
Old 04-09-2008, 10:45 AM   #12 (permalink)
G.A.M.E.R
Shloeb's Avatar
3D Mark PIC.
Just post yours
@mukherjee, close unnecessary processes and disable antivirus too if possible. Then u'll even get a better score than me.
Dell Studio 1558
Shloeb is offline
Old 04-09-2008, 11:18 AM   #13 (permalink)
yesh1683's Avatar
Finally got my radeon HD4850 from Xpertvision from lynx india for 9.4k including all charges and shipping
The brand is actually palit, because in their website they actually using word palit cards
and also this is almost same palit design
itz not default card it has large heatsink and two power connectors so it runs cooler i think
but not installed in system yet as i am getting new PC soon
Here are the pics
Gigabyte GA-EP31-DS3L, C2D E8400, 2GBx2 DDR2800 RAM, WD 640 GB HDD (16MB Buffer)
CM Extreme Power 500WATS SMPS, Expertvision HD4850
yesh1683 is offline
Old 04-09-2008, 11:57 AM   #14 (permalink)
Ethan_Hunt's Avatar
No point cursing myself for buying it a few weeks earlier but I'll start posting my scores once I reinstall XP afresh.
For now my temp idles @52 degrees with 65% fan speed.Loads go to max of 77 degrees.Am pretty satisfied with it.
Guys can we skip the 3Dmark scores & get down to some real time gaming benchmarking.
V for Vendetta
Ethan_Hunt is offline
Old 04-09-2008, 02:20 PM   #15 (permalink)
G.A.M.E.R
Shloeb's Avatar
^^ He has a valid point there.
Dell Studio 1558
Shloeb is offline
Old 04-09-2008, 04:57 PM   #16 (permalink)
At Hell's Disq
hellgate's Avatar
got my Palit HD4850 2day.ran a 3DMark06 bench and scores r pretty good.
got 14677 3DMarks.thats good 4 the starting.
will try oc'ing it more in the future.the best part is the psu that i'm running it with.its a GlacialStars 500W psu which costs just 1.3k.
hellgate is offline
Old 04-09-2008, 06:18 PM   #17 (permalink)
G.A.M.E.R
Shloeb's Avatar
Thats because of ur CPU. 3D Mark 06 is very CPU dependent. Even a overclock of 200Mhz can jump up scores by 1-2k
Dell Studio 1558
Shloeb is offline
Old 04-09-2008, 06:49 PM   #18 (permalink)
At Hell's Disq
hellgate's Avatar
attained a max oc of 691MHz on core and 1069MHz on mem.didnt do any modds till now.oc'd using AMD gpu clock tool.
3DMark06 score is 14864.(SM2.0 -> 5836; HDR/SM3.0 ->7538; CPU -> 3652)
hellgate is offline
Old 04-09-2008, 07:35 PM   #19 (permalink)
guys which drivers u are using please post that too ....
chilling.....
imgame2 is offline
Old 04-09-2008, 09:15 PM   #20 (permalink)
At Hell's Disq
hellgate's Avatar
i'm using Catalyst 8.8 for all my testing.
OS is Vista Ultimate 32bit
hellgate is offline
Old 04-09-2008, 09:41 PM   #21 (permalink)
great but catalyst 8.8 locks the maximum overclock to 685 MHz compare to before 725MHz u are using the ati tool available at techpowerup ...???
chilling.....
imgame2 is offline
Old 04-09-2008, 09:53 PM   #22 (permalink)
At Hell's Disq
hellgate's Avatar
^^ yup i got it from techpowerup.
hellgate is offline
Old 04-09-2008, 10:04 PM   #23 (permalink)
great!!! ...by the i also got my palit HD4850 today it idles at 49 deg ...is it fine ....???
chilling.....
imgame2 is offline
Old 04-09-2008, 10:30 PM   #24 (permalink)
At Hell's Disq
hellgate's Avatar
the temps r good.no probs.
hellgate is offline
Old 04-09-2008, 10:50 PM   #25 (permalink)
cool !!! thanks !!!
chilling.....
imgame2 is offline
Old 04-09-2008, 10:58 PM   #26 (permalink)
mukherjee's Avatar
gr8 news buddy!
by how much did the card get u poorer?
Old 04-09-2008, 11:07 PM   #27 (permalink)
gr8 news buddy!
yes it is i got it along with a corsiar vx450W ...got it up and running without ant hassle ...no driver problem nothing as i suspected ....it cost me 9.7k ..did not check the 3dmark 2006 scores ....
but what about u ???what game u started playing ...? i m installing oblivion ...to see ho it works ....
chilling.....
imgame2 is offline
Old 04-09-2008, 11:40 PM   #28 (permalink)
mukherjee's Avatar
A few CRYSIS runs....
1.1280*1024, run @ High specs
2.1280*1024, run with dx10 hack(high specs)
Old 04-09-2008, 11:50 PM   #29 (permalink)
Google Bot
Pathik's Avatar
Congrats all of you.
Pathik is offline
Old 05-09-2008, 09:51 AM   #30 (permalink)
darklord's Avatar
Interesting thread
darklord is offline
Radeon HD 4870/4850 official game performances charts nish_higher Technology News 85 02-10-2008 11:52 AM
Newly bought machine making me cry !!! deba_2k_1 Software Q&A 6 25-01-2007 05:44 PM
Comedy of Errors.....Lets Discuss speedyguy Gamerz 6 27-06-2006 12:19 AM
DVD writers Lets discuss them in details nisarg16 QnA (read only) 29 07-10-2004 01:40 PM
