Old 02-09-2008, 08:54 PM   #1 (permalink)
ECE0105's Avatar
Question Please suggest Mother Board.
Hi Guys,
I have an old P4 2.8GHz processor (511) whose motherboard died some months ago.
I also have an additional 1 Gb DDR2 (667MHz) RAM and also 2x512Mb DDR1 RAM (Leftover from the old Motherboard), an 80Gb SATA HDD & Cabinet.
Please suggest me a low cost motherboard, so that I can hook up this rig.
This would only be used for running Softwares like QTP, SilkTest, Loderunner and Winrunner with Windows XP as the OS and some regular internet browsing.
This is just to be used as an additional Computer and want to keep the cost as low as possible.
The board can either support DDR2 RAM or DDR1 RAM... I have all other components....
Please help.....
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 04-09-2008, 03:10 PM   #2 (permalink)
ECE0105's Avatar
Default Re: Please suggest Mother Board.
Please help guys... I've searched through the forum, but do not find any new posts on this setup... All P4 related posts are prior to '07
ECE0105 is offline
Old 04-09-2008, 03:14 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
Cant help it. P4 supporting Mobos are out of market.
If you are lucky then get hold of an old 845 chipset. Otherwise, bad-luck .
Psychosocial is offline
Old 04-09-2008, 04:16 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Unless you get a 915 or 865, you're outta luck
EDIT:
Got it:- eVGA nForce 610i
Details:
Based on nForce 610i/ GeForce 7050 chipset , Supports Intel Core 2 Extreme, Intel Core 2 Quad, Intel Core 2 Duo, Pentium EE, and Pentium processors , 1066/800 Mhz Front Side Bus . Memory
2 x 240-pin DIMM sockets Single Channel DDR2 , Maximum of 4GB of DDR2 533/667MHz . Expansion Slot
1 x PCIe x16, 1 x PCIe x1, 2 x PCI , 2 x 32-bit PCI, support for PCI 2.1 , Storage I/O
1 x UltraDMA133 , 4 x Serial ATA 300MB/sec with support for RAID 0, RAID 1 , 1 x Floppy disk drive connector . Integrated Peripherals
7.1 RealTek HD , 10/100 , Multi I/O
1 x PS2 Keyboard , 1 x PS2 Mouse , 8 x USB2.0 ports (4 external + 4 internal headers) , Audio connector (Line-in, Line-out, MIC
There you go.
comp@ddict is online now
Old 04-09-2008, 04:44 PM   #5 (permalink)
ECE0105's Avatar
Thanks a lot bro... But I was going through the Intel website as well and I see that the P4 I have is a 775-LGA, so can I not get a 965 Mobo?
And, eVGA nForce 610i, I heard is a good mobo. May I know its price?
ECE0105 is offline
Old 04-09-2008, 06:05 PM   #6 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
first tell me that is ur processor pin-less ?
if yes then go for d915gav with pin less socket.
Power_user_EX is offline
Old 04-09-2008, 06:27 PM   #7 (permalink)
ECE0105's Avatar
Yep, it is PIN less.....
And, does d915gav support Dual-channel mode for DDR1 RAM? cos as I have mentioned, I have two sticks of DDR400 RAM..
Thanks a lot for your replies.
ECE0105 is offline
mother board help navrajyadav Hardware Q&A 7 16-07-2008 03:26 PM
mother-board help kiranbajpe Hardware Q&A 2 18-07-2007 05:12 PM
mother board gau_pppu Hardware Q&A 2 18-11-2006 05:56 AM
mother board bharat Hardware Q&A 11 09-04-2006 07:45 AM
Mother Board techiways Hardware Q&A 1 24-03-2006 04:48 PM
