Old 02-09-2008, 03:56 PM   #1 (permalink)
Will Power
TheLetterD's Avatar
Wink Latest PC pls Comment
Hey! ive bought a new pc with some prts recomende &some not.pls comment
1.Intel C2D E7200<2.53ghz>
2.7050/630i IGP mother board with 128 mb dedicated
3.2gb Dynet Ram
plz tell will farcry1/2,crysis run it?& at what settings
i hv vista 32bit starter on it
Last edited by TheLetterD; 02-09-2008 at 04:12 PM. Reason: forgot to add more imfo
TheLetterD is offline
Old 02-09-2008, 04:01 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Latest PC pls Comment
farcry 1 will run
crysis and farcry2(yet to be relased) will not run on it
Get atleast a 9600GT or wait for HD4600 series from ATI.
desiibond is offline
Old 02-09-2008, 04:01 PM   #3 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Dont dream without gfx card
I spit Rainbows.
skippednote is offline
Old 02-09-2008, 04:17 PM   #4 (permalink)
Will Power
TheLetterD's Avatar
Hey also comment on ma config!!!!!!!!!!
Old 20-09-2008, 02:34 PM   #5 (permalink)
Will Power
TheLetterD's Avatar
Dudes tell me is a PCIe X16 2.0 graphic card compaitable with a asus P5N MX mobo.if not den i plan 2 buy a palit 8600gt crd.ps. is it safe 2 buy a palit card and is it enough for a 380 watt psu with ma con fig.<at top>
Old 20-09-2008, 02:39 PM   #6 (permalink)
Excessive happiness
furious_gamer's Avatar
Yes.. it will works... coz its backward compatible....
Whats ur budget for gfx card man...
Go for ASUS EN8600 GT which beats any other cards in its class costs around 3k....
400W is recommended as i was used the same mobo,p4 proccy,and a 7600GS which struggles with my 350W PSU...
So better get a 400W PSU like PowerSafe 400W for 1.3k....
BTW ur rig..... y u buy Dynet RAM?
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 20-09-2008, 03:09 PM   #7 (permalink)
Will Power
TheLetterD's Avatar
it was cheapr than others dnt wrry later ill upgrade 2 1gb dynet+2gb kingston.
Old 20-09-2008, 03:17 PM   #8 (permalink)
Excessive happiness
PS Request
Old 22-09-2008, 08:42 PM   #9 (permalink)
Will Power
TheLetterD's Avatar
will d performance degrade using backward compaitability?how much?
and if ma monitor only has a D-Sub<VGA> socket.how much will a converter cost and will d performance degrade?
Old 22-09-2008, 10:01 PM   #10 (permalink)
Violent serenity.
Psychosocial's Avatar
lol the ASUS EN8600GT 256MB GDDR3 is like 5k but there is one other model of 8600GT 256MB GDDR3 which costs 3k. Go for it if you are one budget.
You can also increase your budget and get a Xpert Vision 9600GT 512MB GDDR3 for 5.5k
As per now, Far Cry 1 will run.
Crysis will crawl.
Far Cry 2 might not crawl also.
Dynet RAM is good, dont worry. It sure is cheap and infamous but the performance is good (not excellent...but good ).
E7200 is an awesome CPU.
630i.......best budget mobo now (under 4k).
All-in-all, good config.
Psychosocial is offline
Old 24-09-2008, 01:38 PM   #11 (permalink)
Will Power
TheLetterD's Avatar
thannnnnnnnnkkkkkkk uuuuuuuuu but wat abt considering the PALIT Card???
Old 24-09-2008, 02:09 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yess, it'll come within 6.2-6.5k, and the Xpert Vision will be about 6k, not 5.5k(u've gotta add vat, and if online order, shipping too).
About me:
http://about.me/preetam_nath
comp@ddict is online now
Old 24-09-2008, 02:10 PM   #13 (permalink)
Violent serenity.
which Palit card ?? Palit has so many models.
If you are talking about the Palit 8600GT then its out of your budget.
Old 24-09-2008, 02:18 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
ASUS PCI eXXpress 8600gt 256mb ddr3 @ 3k max(it's a newly released one)
About me:
Old 24-09-2008, 10:53 PM   #15 (permalink)
Point Blanc
he can put 9600GT in that mobo has PCI Express slot.
acewin is offline
Old 24-09-2008, 11:05 PM   #16 (permalink)
Violent serenity.
^^His budget is less.......around 3.5k.
So I suggested a ASUS 8600GT 256MB GDDR3 for around 2.9-3k.
Old 28-09-2008, 04:27 PM   #17 (permalink)
Will Power
TheLetterD's Avatar
thanx ppl .wat abt Zotac 8600GT? is Zotak good & can an asus8600GT dis cheap?how much inferior is it from other asus 8600gt ones?
Old 28-09-2008, 05:00 PM   #18 (permalink)
its difficult to say ..but yes i heard u can get asus 8600gt at that price from lynx ...zotac is good too ...but it won't be greatly inferior to ASUS ....if u can't get ASUS then go for zotac ..prefer ASUS ..
chilling.....
imgame2 is offline
Old 28-09-2008, 06:34 PM   #19 (permalink)
Violent serenity.
Ya.....if u can get ASUS then buy it otherwise Zotac is a trustworthy company......u cant go wrong with any of them!
Comment on my Rig :D pirates1323 Chit-Chat 8 08-05-2008 07:07 AM
Please Comment On My 1st Blog Ecko Chit-Chat 11 26-02-2008 07:11 PM
Ubuntu latest or fedora latest arunks Open Source 23 06-11-2006 02:13 PM
Plz Comment on my New Config (Help with GFX too) Monster_AMD QnA (read only) 5 01-08-2005 04:51 PM
ur comment req vamsum_kris QnA (read only) 5 06-12-2004 10:17 PM
