Old 02-09-2008, 01:27 PM   #1 (permalink)
yesh1683's Avatar
Thumbs up Help me to choose motherboard having PCI-Express x16 2.0 interface
I am upgrading my system I have decided on following
HD4850 (already having in hand)
Intel E8400
2x1GB DDR2 667 MHz
320 GB SATA
19" LCD
Only left to decide with motherboard so hoping for a good advice from digitians
I need following features on it
PCI-Express x16 2.0 interface itz must because my card supports it
But board should be less than 6k
There are good boards with
PCI-Express x16 2.0 interface from AMD at below 6k
If i am not able to get intel boards under 6K then i will go with phenom quadcore AMD system
Gigabyte GA-EP31-DS3L, C2D E8400, 2GBx2 DDR2800 RAM, WD 640 GB HDD (16MB Buffer)
CM Extreme Power 500WATS SMPS, Expertvision HD4850
yesh1683 is offline
Old 02-09-2008, 01:39 PM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: Help me to choose motherboard having PCI-Express x16 2.0 interface
ABit Fatal1ty FP-IN9 SLI for 6.9k
ABit Fatal1ty F-I90HD ATI Radeon Xpress 1250 1333 FSB for 6200
I spit Rainbows.
skippednote is offline
Old 02-09-2008, 01:52 PM   #3 (permalink)
yesh1683's Avatar
Originally Posted by Fatal1ty F-I90HD Specifications
# CPU Supports Intel® Core™2 Duo, Core™2 Quad, Core™2 Extreme, Pentium® D & Pentium®4 Processors with 1066/800MHz FSB
# Chipset ATI Radeon™ Xpress 1250
# Memory 4 X 240-pin DIMM sockets support max. memory capacity 16GB
# Supports Dual channel DDR2 800/667/533 Un-buffered Non-ECC memory
# LAN Gigabit Ethernet controller supports 10/100/1000Mbit LAN connections
# Audio 7.1 CH HD Audio CODEC
# Expansion Slots 1 x PCI-E X16, 2 x PCI-E X1, 1 x PCI
# Internal I/O 1 x Floppy Port supports up to 2.88 MB
# 1 x ATA 133/100/66/33 IDE connector
# 4 x SATA 3Gb/s connector
# 3 x USB header (supports 6 additional ports)
# 1 x FP-Audio
# Back Panel I/O 1 x HDMI™ connector
# 1 x PS/2 Keyboard, 1 x PS/2 Mouse
# 1 x S/P DIF Out
# 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
# 4 x USB 2.0, 1 x RJ-45 LAN connector
# Serial ATA 4 x SATA 3Gb/s with SATA RAID 0/1/0+1
They have not mentioned it consists of PCI-Express x16 2.0 interface
yesh1683 is offline
Old 02-09-2008, 01:54 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ ABit Fatal1ty FP-IN9 SLI is for nvidia cards
ABit Fatal1ty F-I90HD is not crossfireX board.
You have to pay hefty premium of some 13k-15k for x16 link pcie mobo.
under 10k, you can get ASUS P5Q Pro.
CrossfireX with x8 crossfire link.
one such board with x16 pcie link is MSI x48c Platinum but costs around 13k.
desiibond is offline
Old 02-09-2008, 01:59 PM   #5 (permalink)
yesh1683's Avatar
Talking Re: Help me to choose motherboard having PCI-Express x16 2.0 interface
I dont need crossfireX board just any mobo which supports PCI-E x16 v2.0 interface thats it any brand will do but intrested in Gigabyte and MSI boards
My mind is really pushing towards Gigabyte (AMD System) GA-MA78GM-S2H has it has got great features
http://www.gigabyte.com.tw/Support/M...ProductID=2758
Specifications includes
  1. Dual Channel DDR2 1066 for remarkable system performance
  2. Integrated ATI Radeon HD3200-based graphics (DX10)
  3. Ultimate graphics performance with PCI-E 2.0 x16 interface with ATI Hybrid CrossFireX support
And this mobo Costs just 4.4k
I want similar board
yesh1683 is offline
Old 02-09-2008, 02:23 PM   #6 (permalink)
if u dont need X-fire , then any board having pcie slot will do. .pcie x16 1.1 is enough. u'll need pcie x16 2.0 only if u are going for x-fire
sagargv is offline
Old 02-09-2008, 02:41 PM   #7 (permalink)
yesh1683's Avatar
Then y does single PCI-E x16 has 2.0 interface ??
2.0 interface will allow more bandwidth
PCI Express 2.0
PCI-SIG announced the availability of the PCI Express Base 2.0 specification on 15 January 2007. PCIe 2.0 doubles the bus standard's bandwidth from 0.25 GByte/s to 0.5 GByte/s, meaning a x32 connector can transfer data at up to 16 GByte/s in each direction.
PCIe 2.0 is backward compatible with PCIe v1.x. Graphic cards and motherboards designed for v2.0 will be able to work with v1.1 and v1.0. In some cases it is possible that a PCI-E 2.0 card will not work correctly on a PCI-E 1.0a slot. This is only limited to certain video cards.
The PCI-SIG also said PCIe 2.0 also features improvements to the point-to-point data transfer protocol and its software architecture
More at
http://en.wikipedia.org/wiki/PCI_Exp...CI_Express_2.0
yesh1683 is offline
Old 02-09-2008, 02:52 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ dude. I thought you are looking a mobo for Intel processor.
Yep. GA-MA78GM-S2H is a superb board. But make sure you get rev1.1 or higher.
first edition of this board came with a crappy heatsink for chipset and created few heat issues.
newer revision is just fine with a bigger and better heatsink.
For Intel, go for ASUS P5Q.
Old 02-09-2008, 03:08 PM   #9 (permalink)
yesh1683's Avatar
I am looking for intel only
Just if i couldnt get any good one for intel then i will go for AMD
yesh1683 is offline
Old 02-09-2008, 03:24 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
For Intel, go for ASUS P5Q or P5Q Pro (only difference is extra pcie slot) and as the difference is just 800 bucks or less, I would pick ASUS P5Q Pro.
Old 02-09-2008, 03:46 PM   #11 (permalink)
filth is me
forever's Avatar
pci x16 1.1 is more than enough to handle the 4850. anyhow you could look for MSI p43/p45 or Gigabyte ep43 based boards.
forever is offline
Old 02-09-2008, 03:50 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
This is the one for you.
But you won't be able to make use of the Hybrid card performance boost, although it will help in saving your (electricity) bill by quite an amount.
comp@ddict is online now
Old 02-09-2008, 03:51 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
You can save on processor and mobo (for Intel) and with that get AMD config with HD4870
E8400 costs around 8.5k. Go for Phenom X3 which costs 5.5k (saved 3k)
A decent mobo costs 6k-8k. gigabyte 780G chipset mobo costs 4.5k (saved 2k)
add another 3k-4k and get HD4870.
Old 02-09-2008, 03:56 PM   #14 (permalink)
why nobody is suggesting a P45 Neo - F for about 5.8k ??? it has all the things u need
http://global.msi.com.tw/index.php?f...2&maincat_no=1
imgame2 is offline
Old 02-09-2008, 04:14 PM   #15 (permalink)
filth is me
forever's Avatar
forever is offline
Old 02-09-2008, 06:17 PM   #16 (permalink)
PCI Express 2.0
More at
but that extra bandwidth given by pcie 2.0 is not used by any card today .. any minor improvement in performance u see in a board with pcie 2.0 is due to the better chipset . not pcie 2.0
u can be sure that hd4850 will NOT use the extra bandwidth given by pcie 2.0 .
and that incompatibility issue is basically with VIA chipset based mobo's with 8800GT's AFAIK ..most of us are having pcie 1.1 and there are NO compatibility issues at all . NO performance loss. my friend is using a abit ip35 e with a hd4850 and its fine . performance benchies match with those with similar config but with a p45 board sporting a pcie 2.0 interface..
get the pcie 2.0 if u intend to upgrade the card later without upgrading board+mobo.
pcie 2.0 is helpful in X-fire because :
in crossfire enabled p45 boards .. when both the slots are being used , each pcie slot will run at x8 mode. but since its pcie 2.0 , it still gives full bandwidth as that of pcie 1.1 x16. .
get a p45 based board if u intend to upgrade the card later ( atleast after a year ). . getting it just for the sake of pcie 2.0 isnt worth it if u're not going to upgrade.
sagargv is offline
Old 03-09-2008, 07:44 AM   #17 (permalink)
yesh1683's Avatar
Thanx guys for ur valuable suggestions
I will look for MSI if possible
One more last q?
Will core2duo E8400 become hot ?
Does it need CPU cooler ?
I know it can be overclocked to large extent but i want to overclock a little so can i do it without any cooler?
yesh1683 is offline
Old 03-09-2008, 10:22 AM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^^no. unless you insanely overclock E8400 you don't need a cooler.
For a little bit of overclocking you don't need a cooler, you need a good thermal paste to apply on the proccy and 120mm High speed rear fan.
Old 03-09-2008, 01:56 PM   #19 (permalink)
yesh1683's Avatar
^^^ thanx buddy
yesh1683 is offline
Old 03-09-2008, 02:15 PM   #20 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ i dont thinki u'll ned a pcie x16 2.0 slot to get the max out of ur card.even im getting a HD4850 and i'm gonna bech it 2night with my IP35-E.
hellgate is offline
Old 03-09-2008, 04:37 PM   #21 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ While benching, keep temperature sensing software up and running.
Also, unlock the fan speed for your HD4850. afaik, it's locked to a max of 30% of it's potential speed.
http://www.tomshardware.com/forum/25...-heat-problems
the above guide may help you. also search in google for unlocking fan speed lock.
but make sure you test it out completely.
This hack will not void warranty as it is a hack into the ATI catalyst software and not into the graphics card.
Turn the speed to a desired value, do some test, see how the temperature is.
Old 03-09-2008, 06:33 PM   #22 (permalink)
At Hell's Disq
hellgate's Avatar
^^ thnx 4 the link.now dont hafta search 4 it.
hellgate is offline
Motherboard upgrade to support PCI-express graphics card with no change in processor ManojJumani9999 Graphic cards 1 23-08-2008 03:27 PM
Which Motherboard to choose? (ATX) tmbsundar Hardware Q&A 1 30-04-2008 07:28 AM
Which 915 motherboard supports AGP 8X and PCI Express? andysmith45 Hardware Q&A 4 14-01-2006 01:26 PM
