Old 02-09-2008, 12:20 PM   #1 (permalink)
Default AGP Card on D845GVSR
I have P4 2.4GHZ on D845GVSR.Above the pci slots a group of connectors are visible, above which it is written as AGP slot.My question is whether an agp slot added there . If yes please suggest some good performing boards around 2k...PLZ REPLY IMMEDIATELY...
j4jubin is offline
Old 02-09-2008, 03:44 PM   #2 (permalink)
Default Re: AGP Card on D845GVSR
u will be lucky if u find an AGP graphics card altogether ....new ones will be very costly and hard to come by...
imgame2 is offline
Old 02-09-2008, 03:48 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yes it is an AGP slot.
If you want upgrade, the 7600GT is a good choice, but the 3650(although for 6.8k) performs awesome.
comp@ddict is online now
Old 02-09-2008, 03:51 PM   #4 (permalink)
he said budget 2k ...and u are telling him 6.8k card ...???
imgame2 is offline
Old 02-09-2008, 06:31 PM   #5 (permalink)
The Intel D845GVSR does not have an AGP slot. This is a screenshot from the Intel website:
pimpom is offline
Intel D845GVSR Help Needed Ankush_is_here Hardware Q&A 7 22-08-2007 11:58 PM
intel d845gvsr default bios needed j4jubin CPU / Motherboards 1 08-07-2007 09:15 AM
Changing bios , for wake up Computer, main board D845GVSR eureca_eureca Software Q&A 7 26-12-2005 07:40 PM
