Old 02-09-2008, 07:53 AM   #1 (permalink)
Revolution's Avatar
Angry BSNL Sucks !!!
I don't know where shoud I post this.....
I got new BSNL DataOne connection but,I can't connect.
I get an error (678 error) when I insert my id and password.
My modem is 'Siemens C2110'.
It shows all 4 lights is on(power.link,data,lan or usb).
I have registered a complain to BSNL a week ago.
But still no reply from them.....
I have 256kbps UL plan.
In may 2008 I had registered for new broadband connection.
Now after 4 months in september I get the connection but actually no internet connection.....
Worst thing,BSNL already send me two bills.....
I hate BSNL !!!
Never Buy Any fking Palit Card And Be Aware From M D Computer(Kolkata),They Sell Physically Damaged Cards.....:x
Revolution is offline
Old 02-09-2008, 11:35 AM   #2 (permalink)
adi007's Avatar
Default Re: BSNL Sucks !!!
well i think BSNL is very nice
I have BSNL connection since feb
The thing is don't use ur modem ..hire their modem ...if anything happens u will get a replacement(i got once)
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 02-09-2008, 03:33 PM   #3 (permalink)
I hate BSNL !!!
what were u doing when they sent u two bills already charging ur Internet ...???
by the way the person who came and installed the modem should have done all the settings and checked if the net is working....as far as i know BSNL had given tender to private parties to do the modem/connection setup...
first try resetting ur modem-- and restart ur comp...if it doesn't work it could be one of the problems...
1)either ur connection is not configured properly on ur computer.... delete all the network connection install latest LAN drivers configure LAN then add a new PPPoE connection... this should work....
2)if it is configured properly....then ur jumper connection is not configured in local telephone exchange..just call up them and ask.
in the mean time do lodge a complaint about its not working according to new BSNL guidelines,every complaint should be registered and problems to be rectified within 3 working days or maximum a week...if its not done..SDO of ur local exchange is answerable to it.
3)if ur jumper configuration is right with ur local exchange then ..its upto the main Internet exchange (of ur city)..some computer commands needs to be given to activate the connection.which perhaps is not done yet....
if u do the running around for two days ...all these matters can get solved ..including ur bill issue...but again it depends on BSNL staff u have to deal with...i had similar problems as u said ...and i did running around for those things ...and all the time it was fine in three days to a week...
one more reason could be a break in OFC link somewhere ..just check with ur local exchange.
once its up and running....u will not face any problems....but again if u hate bureaucracy or can't afford to run around...BSNL is not for u...its getting better in coustomer services but its just not there yet!!..look for better ISP's in ur area ...kolkata might have quite a few ...
in my opinion BSNL is best internet connection u can get (don't know about others) ....if u can manage with their billing system and bureaucracy ...i stay in raipur and i m using UL256 kbps plan for about two years now...
1)never had any problem in speeds,it really gives u almost constant 256kbs (24x7)..unlike in airtel or other companies i have used....i used to download almost 24x7 from torrent for speeds between (28 kB/s to 34 kB/s)
2)if link is down just call up the service number was restored within 2 days (happened thrice with me) and one more time it was a problem with OFC cable cut due to digging so it took about 7 days....came to know later that its due to new TRAI rule.which must be followed by every ISP.
3)used airtel connection before.... it simply sucks...and out of the blue some taxes in the bill will come up,never could a get constant speeds and whenever i called them they will give some excuse or other.....don't know about other market players in ur area.but BSNL's connection configuration system is the simplest i have come across...
if u still have problems please look here ..i m sure u can get much better guidance there ..
http://broadbandforum.in/bsnl-broadband/
imgame2 is offline
Old 02-09-2008, 03:44 PM   #4 (permalink)
Point Blanc
I hate BSNL !!!
Well I say BSNL is good, even though had gone through same thing. Registered in October got wworking Broadband in February.
For first week it was not working, but the issue was not from my side but from exchange which they fixed. THey are not as responsive as Airtel but still, my most of the issue whenever comes is exchange side and they clear it.
YOu have not seen others like TATA n Sify they are crap. My BSNL after it got configured for first time was not working very less time. And BSNL tariff plans rocks.
I suggest you to go to exchange directly and tell the engineers their they will send someone to get it fixed. Its most probably login error.
I got BSNL connection 4 days back a my hometown also now, my pa said same error, I could not suggest him much. Later on a guy came and fixed it, when pa asked what was the issue he said its due to new wires being put on the telephone poles, and some exhange issue.
Man you will get it fixed, good luck
acewin is offline
Old 03-09-2008, 07:09 AM   #5 (permalink)
Revolution's Avatar
Lol....
BSNL employees never do their duty.
One fcking BSNL employee came to my housh and only gave me the modem.
He told me that every thing is on the modem's CD,do yourself.
And after running the CD every thing messed up.....
Now modem's default setting has been changeg.
BSNL does not care about their customers.
I call them up many times but still no reply.....
Old 03-09-2008, 07:30 AM   #6 (permalink)
Tech.Masti's Avatar
^^^from which exchange you are??? i am also from wb.
it depends exchange to exchange....
Tech.Masti is offline
Old 03-09-2008, 07:33 AM   #7 (permalink)
Revolution's Avatar
Unhappy Re: BSNL Sucks !!!
Ranikhuti,South Kolkata.....
Old 03-09-2008, 07:33 AM   #8 (permalink)
Tech.Masti's Avatar
contact the man on duty for Dataone, tell him your problem
Old 03-09-2008, 11:50 AM   #9 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Hi Dude,
I will tell how to get ur Net - Working!. (Not sure if it works, but u can still try). To start off, u need a LAN card. Connect ur lan cable both to the Modem and PC. Then configure the IP address of ur PC by going to network properties. I think these r all basic steps, so no need of mentioning. Enter any IP other than 192.168.1.1. then enter the default gateway and DNS server numbers in the respective fields. BSNL should have supplied u with this. I am sure.
Now. go to the Browser window (IE only) and type http://192.168.1.1/ . Enter the user and password as admin U will get a DSL router window. Here, go to advanced setup and select WAN.
On the first line u should see these things
0/351UBRpppoe_0_35_1ppp_0_35_1PPPoEDisabledDisabledE nabled
Click on edit. the default values are 0 and 35. click next and select pppoe 2nd option. then clikc next. U will need to enter ur dOne user and password here. clikc next. clik next again. click save/reboot until u recieve a message saying that ur DSL router is rebooting. Wait for 2 mins and u will get a message in the same window stating ur newly configured Router. (Dont go to change any other option. let them be at Defaults only)
Next close that windows nd start surfing. The thing is the DSL router get reset every time u shutdown. It happens with mine. Not sure of yours. Also, I dwnld about 1GB daily. So no issues with speed. I get speed of 26 to 27kBps (27*8). u do the maths.
Also dont connect both USB and LAN together. and there is no need of entering password **** for this thing. All u have to do is surf directly.
Bye
Hi again,
No need of entering through secure login for this method. If u cant surf the net, U can change ur PC ip address and follow the steps given in prev message. It will definately work.
Bye.
No need of giving complaints to BSNL. They will not come. They are donkeys. what u can do is consult a Networking Engineer. I think he can solve ur issue permanently. Bye 8*
ubersoldat is offline
Old 03-09-2008, 04:07 PM   #10 (permalink)
ECE0105's Avatar
I have been using Dataone since May 2005 and have no real complaints.
Four times, the internet stopped working. On two occasions, it resolved itself after a few hours. Once, there was a problem with the telephone line and it was rectified 2 hrs after a complaint was lodged.
Fourth time, the AC Adapter for the modem had a problem and it was replaced for free (I have the modem on rent) and the replacement was done at around 7 PM on a holiday. So, I cannot complain about the service.
In your case however, Uninstall any software you might have installed from the CD.
Connect the Modem with the telephone and LAN Cables and then go to the network settings.
Create a new connection --> NEXT
Connect to the internet --> NEXT
Setup my connection manually --> NEXT
Connect using a broadband connection that requires a username and password --> NEXT
Give the connection name --> NEXT
Enter user and password details.
Once that is done. Power on the Modem, wait till the DSL Light is steady and then connect.
You would need to use this each time you want to use the net, Otherwise, you can follow the steps suggested by "ubersoldat" to have an always on connection.
And, have you tried contacting the local exchange? Better than calling up the Toll Free number.
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 03-09-2008, 04:53 PM   #11 (permalink)
R2K
In the Zone
R2K's Avatar
if BSNL can't help u call a PC technician for help...
anyways BSNL will make u pay the bill at the end of the month and if u don't use the net u r just waisting ur money ... spend some money and call a technician for help
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
Sony Ericsson Xperia Arc S (Gloss Black)
R2K is online now
Old 04-09-2008, 02:28 AM   #12 (permalink)
Point Blanc
really when they stop doing there job it is tough. even complaining their engineers and SDO would not work, they do not respond.
Get your head cool and make sure the exchange guy comes and rectifies the issue or some other technician. Otherwise stop using the broadband services of BSNL.
Get airtel broadband, their customer support is good, but by any means do not go for Tata Indicom or anyother
acewin is offline
Old 04-09-2008, 07:04 AM   #13 (permalink)
Revolution's Avatar
Finally I solved the problem by myself.
1.after open the browser i enter http://192.168.1.1
2.enter id and pw of the modem router
3.clich on the internet connection on the top left side
4.it shows there was an existing connection.
5.I delete that setting(connection)
6.reboot modem
Now almost every thing OK except
1.line disconnected automaticacally(4 times yesterday).
I think the cause is poor quality BSNL servever.
2.Tested speed at speedtest.net
D:265kbps..... U:20kbps.....
File download and upload speed
D:24-30kbps..... U:20kbps.....
I can't play mmorpg even at low setting ans resolution because of above reasons(both).
But 256kbs should be enough for mmorpg like Cabal Online.
At least now I am connected through BSNL broadband but have no idea about futere.....
Old 04-09-2008, 07:12 AM   #14 (permalink)
TechFreakiez.com
Abhishek Dwivedi's Avatar
I also have bsnl UL 256kbps....it sure disconnects a lot...nearly 10-20 time everyday
Personal Log | Star date 05.04.2009: TDF Meet Kanpur was Awesome :D
www.TechFreakiez.com
Abhishek Dwivedi is offline
Old 04-09-2008, 07:50 AM   #15 (permalink)
toofan's Avatar
BSNL rocks but their staff sucks.bsnl is much much better then other services like reliance, tata airtel etc. Its cheaper faster and reliable.
That disconnecting automatically is may be due to the connections you make with the pone line, your basic phone and modem.
Connect them properly that should solve. Actually if these are not connected properly then every time there is a call on your phone and you lift the reciever the connection gets disconnected.
For this the main line should be connected directly to the modem and then you should give the parallel connections from it. BSNL provides a multi-connecter with their modem. So use it as its written in the connector.
toofan is offline
Old 04-09-2008, 07:53 AM   #16 (permalink)
Revolution's Avatar
Lol....
Then how can I play MMORPG using BSNL.....
I chose 256kbps UL plan only for playing online game.
I am so unfortunate.....
I have Sulabh II plan.
I never recharge with IT card and never make call using BSNL telephone expept customer care.
Wires,phone,modem are connected well.
There is no doubt about that......
Old 04-09-2008, 01:04 PM   #17 (permalink)
Lets Do It!
amrawtanshx's Avatar
Using H500 for the past 2 years ...
Worked like a charm.
But I changed ma location ... And now its hell ...
So many dissconnections.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 05-09-2008, 07:44 AM   #18 (permalink)
Revolution's Avatar
Angry Re: BSNL Sucks !!!
Now it is morning.
I am already disconnected 5 times in an hour.....
I have made another complain to BSNL 5 minutes ago.
It was my 6th complain in past 4 days.
Still no improvement..
Old 05-09-2008, 10:21 AM   #19 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Hi,
Sorry for ur problem. I think ur telephone line is having a fault. If there is some noice in ur handset reciever, then disconnection will frequently occur. U can also try to repeat the steps given by me. Also, enter ur Ip address for ur Lan card manually. Dont set it to automatic. What u should do is contact ur friend who is well versed in Networking. Or else, go in for the old formula, Trial and Error.
Bye
Old 06-09-2008, 01:53 AM   #20 (permalink)
Lets Do It!
My problem is solved somehow....
The connection is lot better now.
Atlast.
Old 06-09-2008, 04:23 AM   #21 (permalink)
Point Blanc
telephone line fault, man my phone is dead, no calls can be made or can receive right now. Have not reported to BSNL, but still my internet works clean and good.
acewin is offline
Old 06-09-2008, 08:11 AM   #22 (permalink)
Revolution's Avatar
Hey,
I can't fint it.....
Please help !
Old 06-09-2008, 08:37 AM   #23 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
bsnl disconnects a lot and sometimes don't even connect...
everybody's story bro..
not just urs...so chill
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 06-09-2008, 08:44 AM   #24 (permalink)
hsr
Senior Owner
hsr's Avatar
well to do this you should tell the modem what pppoe process r u dialin wid then oly you can dial from the pc
Read Rules > FAQs > Stickies before posting a new thread. PM me anytime for an issue, and I'll be idle on irc too.
My dream rig.
ლ(ಠ_ಠ)ლ Webchat for Digit.
hsr is online now
Old 07-09-2008, 03:36 AM   #25 (permalink)
Lets Do It!
If the connection is in Bridged mode ... It will work the way ECE0105 has told.No extra information need not be provided.
Old 07-09-2008, 07:38 AM   #26 (permalink)
hsr
Senior Owner
hsr's Avatar
^^if he does not get the autodial feature and reset the modem how will it still be in bridge mode?
My dream rig.
hsr is online now
Old 07-09-2008, 08:35 AM   #27 (permalink)
Revolution's Avatar
So,I have no choice but have to look for other ISP.....
I know each and every Indian ISP sucks in their own way.
Lol.....
Old 07-09-2008, 09:10 AM   #28 (permalink)
hsr
Senior Owner
hsr's Avatar
^^ +1
My dream rig.
hsr is online now
Old 07-09-2008, 03:37 PM   #29 (permalink)
R2K
In the Zone
R2K's Avatar
Lol.....
exactly...
R2K is online now
Old 07-09-2008, 03:41 PM   #30 (permalink)
Lol.....
finally u understood the point ....
chilling.....
imgame2 is offline
BSNL broadband sucks!! Xccentricity Software Q&A 22 21-12-2007 10:02 AM
My Pc Sucks amit2005 QnA (read only) 3 02-02-2007 03:04 PM
Piracy Sucks , Originality too sucks vineet_rajput_grover Software Q&A 9 24-02-2006 04:54 PM
