Old 01-09-2008, 10:41 PM   #1 (permalink)
toofan's Avatar
Default continuous small beeps at booting?????
Hello friends,
My office pc is having a weird problem. There are continuous beep beep sounds at the time of booting and the green light is also flickering but the pc is not starting at all. And on pressing restart button it reboots again and same problem.
How to solve this problem guys??
It is a P4 on gigabyte motherboard with 256 mb ddr1 ram. From past few months its fan are running at full speed whene ever the pc is switched on.
Now please give me the solution. Thanks
toofan is offline
Old 01-09-2008, 11:30 PM   #2 (permalink)
adi007's Avatar
Default Re: continuous small beeps at booting?????
hmmm
Check RAM..(this is the major culprit....sometimes just reinserting RAM will solve the problem)
Then Hard disk
First check whether all components are detected in the BIOS Menu
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 02-09-2008, 06:51 AM   #3 (permalink)
toofan's Avatar
I will check the Ram. But how to go to the BIOS menu if PC is not booting?
toofan is offline
Old 02-09-2008, 07:07 AM   #4 (permalink)
M3TAL H3AD M3
skippednote's Avatar
See man its simple either your ram is incorrectly fitted or gone bad or your smps requires a check up
I spit Rainbows.
skippednote is offline
Old 02-09-2008, 04:06 PM   #5 (permalink)
PhotonAttack
DigitalDude's Avatar
see whether if the CMOS battery is dead..
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
DigitalDude is offline
Old 02-09-2008, 09:09 PM   #6 (permalink)
toofan's Avatar
_
How can you say that.
toofan is offline
Old 02-09-2008, 09:16 PM   #7 (permalink)
filth is me
forever's Avatar
can be anything from a faulty motherboard,processor to faulty RAMs. Observe the beep pattern next time and check this.
forever is offline
Old 04-09-2008, 12:36 AM   #8 (permalink)
Give some work to the IT/ Hardware mantenance staff at your office!!
There's some element of trial and error in resolving such issues related to beeps. Remove the RAM and start the PC..if you get the same error most likley either RAM slot is filled with dust blocking good contact with RAM pins or the RAM chip is dead.
After replacing RAM if the same continues..most likley video card could be the next culprit..after all such tryouts finally it's the CPU to be blamed !! Also visit AWARD Bios , AMI Bios related websiteswhich give possible error explanation for the number of beeps.
Since it's office PC hopefully the IT/Maintenance team should be having sufficient stock of spares to nail down the problem.
patkim is offline
Old 04-09-2008, 07:39 AM   #9 (permalink)
toofan's Avatar
Ya yesterday I called for the maintenance. He tested and found that some part of the mobo is burnt away. six days time to repair it.
By the way thanks guys.
toofan is offline
Continuous Processor Fan Rotation Noise techtronic Hardware Q&A 3 29-07-2007 11:14 AM
long beeps....booting prob!!! archillies Hardware Q&A 8 13-03-2007 09:56 PM
Continuous Logged in at Digit Forum piyush gupta Internet & WWW 29 17-02-2007 06:43 PM
"CONTINUOUS SHORT BEEPS" what does it mean... sude QnA (read only) 9 17-01-2007 08:08 PM
Damn small linux made my pen drive small abhinavchadda Software Q&A 4 17-05-2006 01:25 AM
