Old 01-09-2008, 09:38 PM   #1 (permalink)
SuperMASSiVE
stonecaper's Avatar
Default High Temperature for My p4 machine
Hi,
My p4 prescott processor shows 60 degrees on idle and 70 degrees on 50% working in speed fan...is this normal?plz help as i have limited processor warranty.i have D101GGC m\b and zion 512 mb 200 mhz RAM...thnx in advance
stonecaper is offline
Old 03-09-2008, 06:33 PM   #2 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Default Re: High Temperature for My p4 machine
Hi,
I think u proccy temp is just below the normal level. U can add more cooling fans inside the cabinet for better airflow. This will bring down the temp by atleat 4-6 degrees. You can also apply a thin layer of Thermal Paste b/w the proccy and its heatsink. Also, clean any dust which are accumulated on the heatsink and fan blades of the proccy. Se to that ur proccy temp never crosses 70 Deg.
My friends Intel PentiumD 3.00Ghz runs at 75 Deg during bootup itself. And he complains that it often gets freezed while gaming.
Bye
ubersoldat is offline
CPU temperature 99 deg risqer CPU / Motherboards 20 05-09-2007 12:55 PM
very high temperature of cpu utsav Hardware Q&A 22 27-07-2007 02:31 PM
Configuration doubts for a high end machine....help plzzzz windchimes PC Components / Configurations 24 15-10-2006 09:14 PM
temperature chirayu garg QnA (read only) 2 07-06-2005 02:02 PM
Max Temperature for HDD adorablesrini QnA (read only) 8 13-02-2005 05:18 PM
