Old 01-09-2008, 09:00 PM   #1 (permalink)
Cool Suggest mobo + proc + ram for 4k
Hey guys...
I need to set up a PC for my grandparents... their aging config just died ! Budget is from 3 to 4k, and the PC would be mainly used for browsing and chatting.
Suggest a motherboard + processor + ram combo... (strictly 4k max)
Thanks in advance!
P. S. Would appreciate Chennai prices if u can quote them!
hurricane25 is offline
Old 02-09-2008, 03:03 AM   #2 (permalink)
Default Re: Suggest mobo + proc + ram for 4k
Sempron LE-1200 -- 1.5k
Asus M2N MX-SE or MSI K9N6SGM-V -- 2.1k
512MB DDR2/667 -- 0.5k
Total 4.1k. Prices are approximate. You may be able to get them for 4k.
This is not the cheapest possible combo, but it's a good VFM. E.g., you could go for a cheaper VIA chipset mobo, but they sometimes have stability issues. Or a Sempron 3000+.
Of course you could always buy a used set.
pimpom is offline
Old 02-09-2008, 07:37 AM   #3 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Having m2n mx they can even have some gaming as well........lolz
I spit Rainbows.
skippednote is offline
Old 02-09-2008, 08:14 AM   #4 (permalink)
Could even try the mini itx D945GCLF with integrated atom proccy @3.3k + 0.5k for 512mb.
Let there be music.....
sashijoseph is offline
Old 02-09-2008, 11:22 AM   #5 (permalink)
Like the sempron combo... will look it up!
I came across the atom offering as well... but cudn't find any reviews on it. Can any1 shed more light on that offering?
Keep the suggestions comin...
Old 02-09-2008, 04:07 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Suggestion:
1. Celeron Dual Core E1200 1.6 GHz @ 1.6k
2. MSI Intel 945GC (IGP a boon) @ 2.1k
3. 1GB Transcend Value RAM @ 0.7k
If you want Sempron, then get :
1. MSI K9MM-V based on the VIA K8M800 chipset @ 1.9k
comp@ddict is online now
Old 02-09-2008, 05:24 PM   #7 (permalink)
Intel and VIA integrated graphics are inferior to the Nvidia IGPs of the mobos I suggested, by a considerable margin.
pimpom is offline
Old 03-09-2008, 12:41 AM   #8 (permalink)
wouldn't sempron offer superior performance and good VFM compared to the celeron offering? is dual core celeron a step ahead of sempron then?? confused....
Need Help with Mobo/Proc/Ram?cabinet @ 20k!! suhas_sm Hardware Q&A 2 11-07-2008 07:35 PM
