Old 31-08-2008, 12:17 AM   #1 (permalink)
Always friendly as DIGIT
binilmb's Avatar
Default Help me
Hi everybody,
From the last two days i am having a serious problem. My systems power cut off unexpectedly. Is it the problem of my SMPS ?. And also when I am switch on my system, it doesn't start. But pressing the power button for 5 or 6 times or more it starts.
another problem is that when I am running 2 or more programs, or copying the contents from the CD or Pendrive the above problem occurs
I am checking my memory module on my friend's systems but it was working fine.
Is this the problem of my SMPS or my MotherBoard ?. My sys is 4 years old
And also when the system starts up the keyboard and Mouse did not respond for sometime, after pressing any key for 2 or 3 times they works normally.. Please help immediately
binilmb is offline
Old 31-08-2008, 12:41 AM   #2 (permalink)
Default Re: Help me
As is often the case, there's more than one possible cause and it's best to find it by a process of elimination.
Since you're having a startup problem, disconnect all drives and see if it starts up without having to press the power button repeatedly.
You could also try substituting your PSU (SMPS) with a known good one. Perhaps you could borrow your friend's PSU.
pimpom is offline
Old 31-08-2008, 01:18 AM   #3 (permalink)
Point Blanc
Default Re: Help me
could be due to any hardware. even RAMs gone kaput, but I do not think it will even boot with bad RAM.
Your only chance is elimination process as pimpom said. add each individual componet to your frn's system keeping precaution(do not put your SMPS to his hardware that can be bad for his hardware), once all components are checked change your SMPS.
I think your PSU has gone weak you may really need to change it finally.
acewin is offline
Old 02-09-2008, 01:41 AM   #4 (permalink)
binilmb's Avatar
Default Re: Help me
Thanks for your replies. I am going to be test my sys as you said thaankz
binilmb is offline
Old 02-09-2008, 06:59 AM   #5 (permalink)
toofan's Avatar
Default Re: Help me
Before starting the thread try to give it a proper Title so that it become easy to know actually what the thread about.
"Help me" suggests nothing.
toofan is offline
Old 02-09-2008, 07:35 AM   #6 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: Help me
take it cool man the poor guy is a newbie........ Try to remove the ram then try to put it again or get your smps checked
I spit Rainbows.
skippednote is offline
Old 02-09-2008, 09:45 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Help me
1) reset and update BIOS
2) try using your friend's PC's SMPS in your PC and check how it works
desiibond is offline
Old 02-09-2008, 11:45 AM   #8 (permalink)
.........Access Denied!!!
salilrane's Avatar
Default Re: Help me
i had same prob
but prob was due to over heating
Core 2 Duo 2.53Ghz E7200|Asus P5K PL CM Intel G31/ICH7 Chipset 1333 FSB|Kingston DDR 2*1 GB /800 Mhz|Samsung 2033|Western Digital 250 GB+Samsung 80 GB|Samsung 20x SATA SH-203B|Custom Caby
Help ??
salilrane is offline
