Old 30-08-2008, 10:36 PM   #1 (permalink)
himadri_sm's Avatar
Default Help !!My PC does not BOOT...
When i switch on my ups the cpu turns on automatically & after a few moments it turns off..after some time it turns on but at the POST screen it beeps once followed by 2-3 beeps & then restarts...it hasn't booted even once...what is the problem?
config- P4@2.4Ghz, Asrock p4i45gl m/b, 512 mb ram...
himadri_sm is offline
Old 30-08-2008, 10:50 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Help !!My PC does not BOOT...
Is your processor FAN running ?? Look in side the cabinet and see if the processor FAN is running at proper speed !!!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-08-2008, 03:36 AM   #3 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
The CMOS battery cld be discharged
can you go into Bios? If yes then go into the bios and make changes to boot order, then reboot and see if the boot order is the same..
The Ram cld have gone ka[ut
try to ..
2. remove your ram and put it back again, in a different slot. Also Check power connections to motherboard/hdd
Lastly.. remove all non essential components from ur pc -pci cards, usb stuff, keyboard/mouse cdrom etc etc.
Try to boot.
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Dual boot Linux - boot failure after XP Encryption patkim Software Q&A 1 23-03-2008 11:00 AM
How to boot in xp in safe mode (Vista + XP Dual Boot) CadCrazy Software Q&A 6 14-08-2007 11:43 AM
How to Convert any Boot Floppy to Boot CD VexByte Software Q&A 4 12-05-2007 06:32 AM
PC does not boot (Someone please help) the_player Software Q&A 6 02-10-2006 12:34 AM
i want boot.ini to boot from second HDD without removing it. parthbarot Software Q&A 4 27-09-2004 12:23 AM
