Old 28-08-2008, 12:35 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default maximum cable length of a webcam.
hi friends.
well i want to know what is the maximum length of a webcam cable is.is it 30+ meters.
quan chi is offline
Old 28-08-2008, 12:49 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: maximum cable length of a webcam.
cant say exactly. But you can try wireless cam.
ravi_9793 is offline
Old 28-08-2008, 01:09 PM   #3 (permalink)
mortal kombat
quan chi's Avatar
well then what will be its signal range.can we recieve it from another side of the door.and what will be its cost.
quan chi is offline
Old 28-08-2008, 04:38 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
cant say about pricing..but range will depend on the webcam you choose.
Old 28-08-2008, 07:08 PM   #5 (permalink)
Q1: How long of a cable can I use to connect my device?
A1: In practice, the USB specification limits the length of a cable between full speed devices to 5 meters (a little under 16 feet 5 inches). For a low speed device the limit is 3 meters (9 feet 10 inches).
Source: http://www.usb.org/about/faq/ans5
So if your's is a USB webcam then this could be one limitation. And webcams are generally low speed devices. So for sure it can't be greater than 3 meters.
raghu.nadi is offline
how to use n95 as webcam with usb cable ? myhotdog Mobiles and Tablets 3 13-09-2008 11:47 AM
Max LAN cable length? goobimama Networking 7 03-02-2008 06:34 PM
Maximum Lan cable length question zyberboy Hardware Q&A 8 27-12-2007 09:33 PM
Printer USB cable length ramborums Peripherals 2 11-07-2007 11:16 PM
n70 message length callmeastha Mobiles and Tablets 5 02-02-2007 10:36 AM
