Hi guys, I have a tata Indicom broadband connection. I am not very familiar with the router and modem thingy. All I can say is there is a white box (Presumed as modem + Router) with TNDSL.
I have a PC and a laptop, I want to buy a router with which I can use the laptop in the wifi mode and the PC in a wired mode at the same time, ie LAN.
My Laptop runs Vista Ultimate
PC runs Xp pro SP3
Please put in all the suggestions.
www.harivarrier.com
Check out to earn money...
1st ask the tata guys if they provide u with a WiFi router in staed of ur current one.if yes then ur prob is solved.
also if u want u can always get a wifi card 4 ur pc for 1.2-1.5k.
OMG, 50 meters is too much buddy. I think you are thinking of getting internet for your neighbours. The range of routers generally comes to 10-20 meters
Secondly taking the Wifi router from Tata Indicom customer is not such a good idea. as I do not think there routers such good to have coverage of so much area.
