Old 27-08-2008, 08:02 PM   #1 (permalink)
Default pen drive-help needed
I seem to have developed some problem in my computer. It reads pen drives when connected to the USB port, but cannot autoplay, open or explore them. I can send files to it, but cannot see them. If I need to access a file, i have to 'search' for it, and then open it from the search results. But only read, no copying. I need to carry work from home to office and vive versa, so its really a big problem. Please help. It happens with all brands of pen drive. I am working with Windows XP.
pradhansushil is offline
Old 27-08-2008, 10:51 PM   #2 (permalink)
toofan's Avatar
Default Re: pen drive-help needed
No1 update your antivirus then make a system scan at boot time. then scan and formate the pen drive.
Solved.!!!!!??
By the way the auto play function should be disabled because it gives you time to scan the usb drive each time you connect it to your system.Its safe this way.
toofan is offline
Old 27-08-2008, 11:20 PM   #3 (permalink)
Roadripper's Avatar
First scan wit a NOd32 or avast do a clean format of urpendrive man ...its prolly infected...
GA-8i915ME-F6
512 mb ddr 333 Mhz-4Sale
E8400 + EP31 DS3l
4gb patriot + Galaxy 8600gt OCed256mbddr3
Cm600W 160gb +500gb sata2+ Creative Xlive 7.1 + 5.1
Zeb antibiotic Amigo 120mm & Xigmatech fan
Roadripper is offline
Old 28-08-2008, 12:20 AM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
Scan it with NOD32 or Kaspersky.
Also you should disableAutorun on pendrives as a safety measure
Regards,
The Conqueror
The Conqueror is offline
Old 29-08-2008, 06:48 AM   #5 (permalink)
Red face Re: pen drive-help needed
Thanks a lot folks. Did all that. I have avast at home and kaspersky at work on the LAN. Formatted three times over. Still doesn't work !!
Help still needed.
Old 29-08-2008, 07:59 AM   #6 (permalink)
toofan's Avatar
Either your pen drive gone nuts or your system is still infected with Virus. I too use avast. Use the boot time scanning option.
If its a virus problem check my the post no 8 in the following link.
Unable to System Restore; Computer Admn hijacked by some one. Help Restore it to me.
toofan is offline
Old 29-08-2008, 11:56 AM   #7 (permalink)
paroh's Avatar
May be ur pen drive is infected with some virus. Scan ur pen drive with some good antivirus. and install USB disk security.
paroh is offline
Best dvd drive suggestion out of experience needed blister Hardware Q&A 81 14-01-2008 11:38 AM
help needed pen drive with mp3 player devilzdad Software Q&A 5 11-07-2007 10:02 AM
Optical Drive Booting Query/Help Needed dissel Hardware Q&A 5 22-02-2007 01:21 AM
Help needed- ibm laptop combo drive not working shivkumar Hardware Q&A 3 20-08-2006 04:27 PM
help needed in buying a combo drive shikhar_kapoor143 QnA (read only) 7 13-08-2005 01:45 AM
