Re: GLB 502T+ Need Help
it need not be reset,
if u jus wanna enable adn disable it (without the hard wired approach), goto Control Panel > network Connections > ur router wud be displayed there as LAN connection, rt. click on it, and tick the SHOW icon in notification area.,
also, goto device manager, ur router will be displayed under n/w adapters, so rt. click on it and select, ENABLE this device..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
