Old 26-08-2008, 04:36 AM   #1 (permalink)
Seed is the Life!!
shift's Avatar
Default connecting 2 PC
i searched a lot of thread but cant find any thread that help me, so i created this new one
i have a PC with 2 LAN port and DSL internet connection
and i wnt to connect with laptop ( 1 port internet IN and 1 OUT to laptop) using cross cable
the first night i bought the laptop, i was able to connect within 5 mins, but the next morning it refuse to connect
i've tried the same method like before but internet is not working in laptop
files can be shared, got ping reply from both sys but still internet is not working in laptop
both firewall is turned off
please, guys, help me with this step by step ( if possible, from the very beginning )
OS is both XP Professional
thanks in advance
EDIT : from laptop, i cant get ping reply from the port connected to modem
Stupidity Causes Cancer !!
shift is offline
Old 26-08-2008, 12:44 PM   #2 (permalink)
Point Blanc
Default Re: connecting 2 PC
what gaeway u have set in your laptop
acewin is offline
Old 26-08-2008, 01:05 PM   #3 (permalink)
Seed is the Life!!
shift's Avatar
the default gateway for ISP is 192.168.1.1
so i just use like the the default one
shift is offline
Old 26-08-2008, 03:21 PM   #4 (permalink)
Point Blanc
Her it goes, your default gateway should be the PCs IP, actually the IP of the second card.
Make the IP for LAN card as 192.168.2.1 and your laptop as 192.168.2.2
subnet 255.255.255.0
Your modem would be 192.168.1.1 and your system IP through the LAN card conneced to modem would be 192.168.1.2
acewin is offline
Old 26-08-2008, 04:42 PM   #5 (permalink)
Seed is the Life!!
shift's Avatar
hi acewin, can we talk on yahoo messenger?
shift is offline
Old 26-08-2008, 04:54 PM   #6 (permalink)
Point Blanc
I replied u in pm my messenger ID. add me up. I am online now.
acewin is offline
Old 27-08-2008, 12:18 AM   #7 (permalink)
Seed is the Life!!
shift's Avatar
i set up everything right but no internet connection on laptop
and.... finally i solve my own problem
i called up AIRTEL customer care and they told me that it cannot be connected to 2 system without using router or switch
acewin.... thanks anyway
shift is offline
Connecting PC To TV BBThumbHealer Hardware Q&A 4 15-07-2007 04:26 PM
Connecting PC ??? vineetrocks2005 QnA (read only) 3 07-04-2007 02:09 PM
Connecting two PCs with USB nil_3 Peripherals 2 04-08-2006 11:11 AM
Connecting PC to TV? jerry146 QnA (read only) 4 23-03-2005 12:43 AM
connecting two pc in lan Networking 8 08-02-2005 10:15 PM
