Old 24-08-2008, 02:06 AM   #1 (permalink)
Default Hey Guys, A little help please ( AGP Card Display issue) - Urgent
all of a sudden my desktop has started looking like this:
i have tried reinstalling the ati drivers( old and new both)
even reinstalled windows from scratch, but their is no improvement.
when i check the d3d tests all tests are successful. Don't understand why the desktop look like this.
my system specs:
agp card :- gigabyte ati radeon 9600
p4 3.0 ghz
kingston ram :512mb *2 + 128*2
segeate 80 gb sata
os windows xp
drivers :ati catalyst latest version.
please please try to suggest a possible resolution.
Thanks a million.
Bye,Take care
xtremegforce is offline
Old 24-08-2008, 02:15 AM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: Hey Guys, A little help please ( AGP Card Display issue) - Urgent
Does this kind of display comes only in Windows or at BIOS also? If its at both places, then most probably something is wrong with your display hardware. External Display Cards go kaput without any warning, i lost one 4 months ago. But if it comes only under windows, then try booting a linux live cd and see if it happens there also. If it happens both in Windows and Linux, then also its a hardware fault. Otherwise, a reinstall of windows along with latest catalyst drivers will do, i guess.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 24-08-2008, 02:50 AM   #3 (permalink)
It most probably means that your card is gone, probably the memory. Sorry. Sometimes, a defective gfx card shows little or no display problem in POST or Safe Mode, but breaks up when it has more work to do.
pimpom is offline
Old 24-08-2008, 09:51 AM   #4 (permalink)
thanks a million Krazy_About_Technology & pimpom for replying
this happens right at the windows welcome screen and goes worse by the time i log onto my acc. and the desktop appears.
btw this happens in all applications except ie. the ie screen is absolutely clean. why is that?
i even tried cleaning my agp card to remove any dust etc.
if there are no drivers the display is absolutely fine , the moment i install any version of catalyst drivers tthe result is disaster.
Old 24-08-2008, 12:51 PM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
^^^ Then it is surely a driver problem. Actually ATi drivers are renowned to screw up the system big time. BTW which previous driver actually worked in your case ? I mean the last version with which the card was working fine. Install that one and retry.
debsuvra is offline
Old 24-08-2008, 03:28 PM   #6 (permalink)
Well in that case, The easy way will be to download the latest drivers from ATI's website and then fresh install your OS. You can also try removing the driver completly from your system and use the VGA genric driver forcefully from device manager (if you can manage to work this far on your screen, that is) and see if the anomalies are present. If they are not then its a driver problem and you may have to wait for the next release or fallback to a previous one.
Old 24-08-2008, 04:14 PM   #7 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
My advice; Why don't you revert to the older driver you have been using since long?
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
Last edited by IronManForever; 24-08-2008 at 04:32 PM. Reason: Automerged Doublepost
IronManForever is offline
Old 24-08-2008, 11:56 PM   #8 (permalink)
i have already tried reinstalling the windows from scratch and even used the default radeon driver and also tried the driver from the driver cd that came with the package.
i tried catalyst v7.2 and even v7.7 but none of them work.
btw I am able to get a clean display by lowering the hardware acceleration by two points from the troubleshooting panel in the display properties. If the hardware acceleration is full then i get the same display as the image above.
but the disadvantage is that I m not able to Maya or max and experience the same display issue.
i wanted to ask you guys ,by any chance is there a possibility of motherboard being faulty.
thanks a million to all of you for the solution
bye, take care
Help me Guys..my new LG monitor doesnt display to its mentioned resolution... hellboy_extreme Hardware Q&A 1 26-04-2008 11:31 AM
URGENT GUYS PLS TELL Regarding PSU.... nishantv2003 Hardware Q&A 10 06-11-2007 10:14 PM
Issue with Intel 915GAV motherboard... display screwed up.. kaps_2222 Hardware Q&A 1 18-04-2007 10:54 AM
Guys See: Chip December issue not out yet GeekyBoy Random News 3 06-12-2006 10:27 PM
Very Urgent Guys darshanwadikar Software Q&A 8 15-06-2006 07:57 PM
