Old 24-08-2008, 12:41 AM   #1 (permalink)
Unhappy strange virus problem plz give it a look(very urgent)
Hi everybody once again i need ur help
yesterday i connect my flash drive to my system and it detected a virus
but i was not able to clean it and i thought it enters in my system too
from that point i m facing some problems.
I scanned my system and my antivirus app got some infections
I deleted those files and when i m starting my system a message shows at startup that svchost.exe not found and taking long time to boot
and now its not detecting my external hdd's
guys tell me what to do.
thanks in advance
vabhu is offline
Old 24-08-2008, 08:27 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: strange virus problem plz give it a look(very urgent)
What virus client are you using..??
asingh is online now
Old 24-08-2008, 10:41 AM   #3 (permalink)
Save the WORLD !!!
Kulz's Avatar
What antivirus are you using and do you get any message when your external HDD fails to detect?
Save the WORLD
Kulz is offline
Old 24-08-2008, 11:31 AM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
Which Antivirus software are you using?
Regards,
The Conqueror
The Conqueror is offline
Old 24-08-2008, 12:20 PM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: strange virus problem plz give it a look(very urgent)
I presume your AV software detected the viruses that had previously infected svchost.exe and then it deleted the infected svchost altogether. I know it sounds ridiculous but it even happened to me with Avast before.
U need to repair your OS through Windows XP installaion CD if it was the case.
debsuvra is offline
Old 24-08-2008, 01:28 PM   #6 (permalink)
thanks guyz for reply
i m using AVG free edition
vabhu is offline
Having a strange problem! Is it a virus or trojan? ajayritik Software Q&A 3 25-01-2008 10:07 AM
Strange Virus In My System Josan Software Q&A 7 23-06-2007 05:43 PM
virus problem very urgent raysoni_r Software Q&A 4 22-01-2007 08:25 PM
Strange virus - tell me what it is! knaadhan Software Q&A 5 28-09-2006 12:48 PM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
