Old 22-08-2008, 03:45 PM   #1 (permalink)
Exclamation Upgrade my Lappy : Suggest Upgrades plzzz
Hi All
Here's the config of my lappy :
Model
VGN-C13G/B
Platform
Intel® Centrino® Duo Mobile Technology
•Intel® Core™2 Duo Processor T5500 (1.66GHz) *1*2
•Intel® PRO/Wireless 3945ABG Network Connection
•Intel® 945GM Express Chipset
Operating System
Genuine Windows® XP Home Edition with Service Pack 2 (English version)
Processor System Bus
667MHz
Memory Bus
533MHz
Cache Memory
L1 Cache: 64KB L2 Cache: 2MB (on CPU)
Main Memory
512MB DDR2 SDRAM*3 (upgradeable up to 2GB)*4
2 SO-DIMM slots (The pre-installed memory module uses one)
Hard Disk
80GB (HDD Recovery Storage:7GB*5, C:40GB, D:Remain ) Serial ATA, 5400rpm
I want to upgrade my RAM and hard disk, within a budget of 4000.
Please suggest some gud options
Wil;l shOOt ya!!
slask is offline
Old 25-08-2008, 01:41 PM   #2 (permalink)
Default Re: Upgrade my Lappy : Suggest Upgrades plzzz
No suggestions ????
Wil;l shOOt ya!!
slask is offline
Old 25-08-2008, 03:24 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Hello,
Certainly, upgrade is possible
1 GB DDR-II 667 MHz Laptop RAM is Rs. 1100/-
160 GB SATA 5400 RPM is between Rs. 2600 to Rs. 3000/-
so under your budget of Rs. 4k you can get another 1 GB RAM along with 160 GB HDD... both of them are plug n play so you just need to remove the hdd / ram bay cover under your notebook to attach them (refer to your manual for details)
thanks
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-08-2008, 03:40 PM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
And see if you can squeeze in more Rs. 300. You can then buy a case for your old HDD.
You can use both your rams together.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Plzzz help needed urgently to upgrade smile Hardware Q&A 8 12-12-2007 02:16 PM
PLZZZ suggest !!! sophocles1997 Hardware Q&A 7 07-09-2007 10:31 PM
PLZZZ Suggest a game!! hpindia Gamerz 2 14-08-2007 11:33 PM
suggest me upgrades.... mukul Hardware Q&A 11 19-07-2006 09:17 AM
plzzz suggest me the best cam phone below 10k pvr_harish Buying Advice 4 26-07-2005 12:18 PM
