i hav a hp 500 notebook with 512 mb ram win xp pentium m 2.00 ghz processor
no gfx card is present
i wish to upgrade it with 2 gb ram & agraphic card(for gaming)
is it possible? if yes suggest the card my budget is 5000-8000 rs
the card should be as cheap as possible and my priority is performance
Incase of Desktops we see external graphics cards getting connected via plug and ply PCIe / AGP slots, where as to save space in notebook graphics cards are not like plug and play..
The chip / memory of the actual GPU is soldered in to the motherboard like an onboard grfx, hence you cant detach it to insert another powerful card
