Originally Posted by altecmayank
but isn't the cache of 2MB and a 65nm technology inferior????
Well if you are compareing just the processor then Intel is better any day, computer is not just about processor.
If the processor is not given supported range of performance hardware the over all performance wont be as per expectation, so under a tight budget, when we compare AMD vs Intel, amd always wins because of cheap but performance hardware
AMD Phenom X4 9550 @ Rs. 7700/-
Gigabyte GA-MA78GM-S2H @ Rs. 4400/-
HD 4850 @ Rs. 12k
would certainly out perform a same budget Core 2 range system
