Old 20-08-2008, 05:14 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question All about Compatibility???
How far is this statement correct ?
1. For Windows XP 32-bit maximum RAM one can install is not more than 3.5 GB
2. For 64-bit OS maximum RAM can go above 4GB
3. The same applies for 32bit & 64bit Vista ?
4. What about Linux OS ???
Zangetsu is offline
Old 20-08-2008, 06:31 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: All about Compatibility???
Wrong !!!!
Wrong !!!
Yes, memory statements are same with Windows XP / Vista
What about them ??
Few facts,
x86 platform by default would support 3 GB of RAM, where as you may use PAE (Physical Address Extension) switch to make them support upto 64 GB (Win 2k3) of system memory !!!
However in x86 platform though /PAE would allow more than 3 GB of system RAM but applications would not be able to use more than 3 GB per process, hence one may need to use /3GB switch also
x64 platform by default would support upto 128 GB of system RAM in case of Windows XP / Vista where as 2 TB in case of server platform
There would be no visual difference between a x64 and x86 edition of Windows, only the background core is different
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 21-08-2008, 12:23 AM   #3 (permalink)
Point Blanc
also 32 bit vista has no issues identifying 4 GB RAM.
Its just XP where u get the problem and microsoft gave the solution.
Linux works on common specifications. And they get updated much more than XP or Vista, these things managed by kernel updates. All new Linux distros are free from any such glitches
acewin is offline
Old 21-08-2008, 10:07 AM   #4 (permalink)
Fullbring
Zangetsu's Avatar
what can we use more than 3GB RAM on 32 bit XP...if yes,then how...
Zangetsu is offline
Old 21-08-2008, 12:37 PM   #5 (permalink)
Rebooting
Did you read my post ??
I did say and have given link of PAE switch which would allow you to use more than 3 GB of system RAM !!!
http://www.microsoft.com/whdc/system...AE/PAEdrv.mspx
rebooting
ChotoCheeta.com
ram compatibility!! BULLZI Hardware Q&A 8 11-07-2007 11:44 AM
ram compatibility rahul30 Hardware Q&A 7 10-06-2007 05:19 PM
RAM Compatibility bhoolkumehul Hardware Q&A 4 04-02-2007 07:58 PM
RAM compatibility vish1988 Hardware Q&A 8 26-12-2006 11:20 PM
64 bit compatibility vipashdigit QnA (read only) 4 29-11-2006 11:39 PM
