if it can be set then it can be change
you only have to check each settings in the administration page of the router
Firstly, thank you.
Secondly, I have no idea what so ever about Routers, could you give me a link so that i can read it and do ? Or if it's a small thing, It'll really be of a great help, if you can explain it here.
Everyone's got a good life, i got the best.
i dont have this router...so i dont know the specific
but u can try out the option under WAN..look for something like security mode..with WPA, WEP or similar as option
if WPA selected and TKIP as the algorithm then you can enter the passkey/WPA shared key in the textbox field and thats it..
then u have to set it to the same shared key in the wireless adapter in your laptop or desktop
