Old 19-08-2008, 06:27 PM   #1 (permalink)
Default Transcend jetflash V10 problem...
Hi Guys,
My pen drive (4GB)shows "Please insert disk" when pluuged into the sys ... i can't format or either use other format s/w,tools... and shows 0 byte... please suggest a way..
abhadi is offline
Old 20-08-2008, 08:10 AM   #2 (permalink)
Default Re: Transcend jetflash V10 problem...
by the way how much did you pay for the 4GB transcend v10 jetflash?
try in another PC
realdan is offline
Old 20-08-2008, 09:23 AM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
which OS ?
did you try +parted magic live cd for formatting it ?
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 20-08-2008, 10:57 PM   #4 (permalink)
@realdan ...4 Gb transcend cost Rs.600 with 1 year warranty... I've tried in other sys too... but the same result
@metalheadgautham .. i've windows XP .. .. i'll check out this s/w .. thanks ..
tried the s/w too..... no use.. shows unknown disk...
OK then i guess, i have to get the replacement of it...Thanks for the help...
abhadi is offline
Transcend JetFlash V60 USB drive is not working durai.pti Hardware Q&A 1 05-08-2008 08:44 PM
Problem with Transcend 8 GB Pen Drive mrbgupta Hardware Q&A 9 22-02-2008 04:47 PM
Review : 4 GB Transcend JetFlash V30 USB Drive dr_jimit Peripherals 5 31-08-2007 02:12 PM
