Old 19-08-2008, 11:48 AM   #1 (permalink)
Techans
nikhilpai's Avatar
Default Dead Pixels on Dell Inspiron
I have a Dell Inspiron 1420 laptop which I bought in November last year.
It has now developed 2 dead pixels on its screen.
Does Dell replace screens having 2 dead pixels? What is their policy?
I have the normal 1 year NBD warranty.
I blog at www.techans.com and tweet at @nikhilpai (Previously known as nikeel on these forums)
nikhilpai is offline
Old 19-08-2008, 10:08 PM   #2 (permalink)
Point Blanc
Default Re: Dead Pixels on Dell Inspiron
check with Dell support. they will tell you.
acewin is offline
Old 19-08-2008, 10:53 PM   #3 (permalink)
In search of light...
abhi.eternal's Avatar
you need to have at least 6 dead pixels if you want a screen replacement from dell. however, if you have one at the dead center of the screen, then you might get an immediate replacement.
http://abhijeetdeb.com
abhi.eternal is offline
Old 20-08-2008, 12:26 AM   #4 (permalink)
Lets Do It!
amrawtanshx's Avatar
6 Dead pixels gets u a replacement.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 20-08-2008, 05:53 AM   #5 (permalink)
Super Moderator
asingh's Avatar
How does one identify the 'count' of dead pixels..?
asingh is online now
Old 20-08-2008, 08:39 AM   #6 (permalink)
dell said
Some suspect pixels, whether white, black, or discolored, can be restored by lightly rubbing the panel.
1. Locate the suspect pixel on the LCD panel.
2. Using a clean, soft cloth, lightly tap the pixel.
3. Using the cloth, apply light pressure to the pixel and rub in a circular motion around the pixel
realdan is offline
Old 20-08-2008, 09:47 PM   #7 (permalink)
Regd this I have a LG LCD flatron model no L1720B n I've got a similar problem only here these dead pixels seem to be increasing daily... every day when I switch on the monitor, the black line has grown, I dont know how to stop this from happening... Do u guys know if LG has a lifetime warranty for the screens ? I bought this monitor 3 yrs back n the guarantee period is over...
Huzefa is offline
Old 20-08-2008, 11:50 PM   #8 (permalink)
i dont think so
realdan is offline
Dell Inspiron 1525 vamsi360 Reviews 18 26-01-2009 09:26 AM
Dell Inspiron XPS vmp_vivek Hardware Q&A 9 23-12-2005 02:47 PM
