Old 19-08-2008, 10:25 AM   #1 (permalink)
Default problem in dvd writer
i hv dvd writer.. its is working properly when i insert dvd but it shows nothing when i insert cd...where is the problem?is their any hardware issue..or software......?
kuldeepsidhu is offline
Old 19-08-2008, 10:33 AM   #2 (permalink)
Default Re: problem in dvd writer
check the connectivity with motherboard of dvd writer
Try any other cd on it, look it's taking proper driver for dvd or not..........
naveen_baldwa2001 is offline
Old 19-08-2008, 04:11 PM   #3 (permalink)
i hv tried tht also but ..problem goes on.....
Old 20-08-2008, 08:54 AM   #4 (permalink)
your dvd drive make?
i think the dvd drive has diff lens for dvd and cd so the cd lens is having a problem
the things that u can try to resurrect it are cleaning the lens with a cd lens cleaner or claim warranty if it is still under warranty
realdan is offline
Old 20-08-2008, 11:21 AM   #5 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
is ur drive a samsung one !! and yes, do get a CD lens cleaner, phILIPS CD lens cleaner is available in the market for Rs.120/-
I once had this same problem, and after getinng a CD lens cleaner, everything was working fine..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 20-08-2008, 12:20 PM   #6 (permalink)
Kalyan's Avatar
What is your DVD model no? I am having Sony DRU190A DVD writer and have the same problem. My friend said that the laser might be a problem. when I insert a dvd, it is not even trying to read it. I have returned it to the service center. Need to wait till it returns.
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is online now
DVD Writer problem amey_dude Hardware Q&A 12 15-04-2007 06:02 PM
DVD Writer Problem caveman Software Q&A 7 23-03-2007 11:36 PM
dvd writer problem purujitb Hardware Q&A 3 16-02-2007 01:40 AM
DVD Writer Problem er.darshan Hardware Q&A 6 06-05-2006 11:25 PM
CD Writer Problem Vyasram QnA (read only) 14 24-03-2005 11:55 AM
