19-08-2008, 09:25 AM
>>>>>Monkey Power<<<<<
How to verify speed of RAM
I plan to buy a new PC and my config is also finalized.Thanks to help from all you guys. Now , when purchasing I need to verify that all the component I get is what I asked for. As it is possible to check seal and cover for almost everything except for the RAM, which usually the vendors give without any packing. Even though it has a sticker stating infos but I need your guidance on understanding it. How do I confirm the speed of RAM, I am planning to get 1 GB DDR2 800 MHz (Kingston) or 1GB DDR2 667 MHz (Corsair) based on availability.
Thanks in advance
If you want to be happy, be.
19-08-2008, 11:44 AM
Core i7 (nehalem) Owner
Re: How to verify speed of RAM
the RAM has ICs on it, so u can check the speed printed on the IC (i think tats the way to confirm it)...
or best, b4 u buy it, and if its not in a packed/sealed condition, tell the vendor to put on a working mobo, switch ON the PC, goto bios and see the speed..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
19-08-2008, 12:32 PM
Violent serenity.
Bios
19-08-2008, 01:11 PM
Cool as a CUCUMBAR ! ! !
try mem tester .....
... W H O T ...
19-08-2008, 01:21 PM
It doesn't matter!
RAM sticks from transcend do come in sealed covers and have a limited detail on da cover itself..
19-08-2008, 01:48 PM
Google Bot
BIOS, CPUZ. There are many other tools.
19-08-2008, 03:15 PM
>>>>>Monkey Power<<<<<
Friends,
I know of few s/w tools but that may not be feasible when buying ram. I can only test them by putting them in mobo. But if Transcend RAM coming in packing, I may buy the same.
BTW, whether its advisable to buy 1 2GB ram or 2 1GB ram?
19-08-2008, 04:19 PM
You can get slightly faster performance (a few per cent) by using two matched RAM modules in dual channel if your moitherboard supports dual-channel mode. But if your mobo has only two RAM slots, installing two sticks will prevent adding more RAM later. If you have 4 slots, I suggest you use 2x1GB instead of a single 2GB stick.
19-08-2008, 04:21 PM
Elevating Humanity
Best if u check it from BIOS
Regards,
The Conqueror
19-08-2008, 04:50 PM
If you plan to buy Kingston or Corsair or Transcend, then insist for a sealed pack.
Genuine stuff will have the specs printed on the case itself so shouldnt be much of a problem.
19-08-2008, 05:03 PM
The Boss
also tell the shopkeeper to sign ur rams .. and write warantty info on the sticker itself with his siggy..
desi but cool ... and tell him ur gonna replace the stuff if it dosent meets ur recommendation.. btw i suggest you buy 2*2gb ram.. especially if ur goin to use vista. may seem a bit aggregrate.. but it is the cheapest way to supercharge ur pc.. but nyhow a lot depends on other components... u seem to know ur tech so decide urself
G3N10U5 BY B1RTH, HACK3R BY CH01C3
E5200; Biostar P43-A7; Palit GF 9600GT; Corsair 4GB; CM extreme power 390W
19-08-2008, 05:49 PM
Violent serenity.
^+infinity.
19-08-2008, 07:02 PM
Super Moderator
Just keep the "part numbers" in mind when purchasing. I plan to get : Corsair TWIN2X2048-6400C4DHX.
Google the part number. It will give you the speed+latencies. Match the part number to the packaging. It HAS to be on the packaging, even if functional details are not.
Best of luck..!
19-08-2008, 09:07 PM
^^ Good luck finding that kit here  you will find only 6400C5DHX here, C4 is hard to find.
19-08-2008, 10:05 PM
Point Blanc
part number, and the seal, gives you the idea even before you buy and the RAMs are open. Transcend, Kingston n all come seal packed.
Then comes our Benchmarking tools, all menitoned earlier by everyone.
19-08-2008, 10:54 PM
Super Moderator
20-08-2008, 10:20 PM
Project Halcyon V2.0
Use CPU-Z.
Download from- http://www.cpuid.com/cpuz.php
This can show your RAM speeds in real time windows environment.
Project Halcyon v2.0:
20-08-2008, 10:21 PM
Lets Do It!
+1 for CPU-Z
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
21-08-2008, 09:40 AM
#19 (permalink)
Originally Posted by tkin
I guess he wants to know how to identify the RAM at the time of buying.
22-08-2008, 12:23 AM
#20 (permalink)
Some manufacturers put a small sticker on the side which includes model no and sometimes speeds and latency as well. Look for that.
