Re: TV Tuner Card REMOTE Problem..Urgent help required
Actually I haven't checked that because it is a new one supplied with the tv tuner card itself.
I'll check that and let u know then...
Thnx for the hint
If still it is not working then i know the reason. It needed a remote patch. I am also using the same model tv tuner. After installing the remote patch (size only few KB ) , it start working.
If u need that i will send to u
Vikas
Originally Posted by achtung
also after connecting the cable line, most of the channels are flickering.
While H/W or S/W failure can not be ruled out, the flicker could simply be due to need of fine tuning. Do check the application and look for fine tuning settings.
