Old 18-08-2008, 03:10 PM   #1 (permalink)
assasin007's Avatar
Default Plzzzzzzzzz Guys Help Me Out :(
hello gamerzzzz and digiters,
i need a graphics card desparately for my PC. the conf is AMD SEMPRON 2800+ 1.6ghz with 512 RAM. i kno its not evn a byte of gamin pc. pls help me find out a decent but cheap card upto 3000. m in pune
assasin007 is offline
Old 18-08-2008, 11:54 PM   #2 (permalink)
mayanksharma's Avatar
Default Re: Plzzzzzzzzz Guys Help Me Out :(
care to mention ur motherboard specs?
btw, within that budget...zebronics 8600GT could be an option. however i doubt whether ur mobo will support a pci-e gpu or not!
mayanksharma is offline
Old 19-08-2008, 01:09 AM   #3 (permalink)
As mayanksharma said, you have to tell us about your motherboard. Does it have an AGP or a PCI-E slot? If you don't lnow, tell us the brand and model number of your motherboard.
pimpom is offline
Old 19-08-2008, 03:06 AM   #4 (permalink)
A LOTR fan
x3060's Avatar
i think its an agp one...you can go for 2600 from ati or 7600 gt from nvidia (well if gt ain't available then 7600 gs 512 mb is)...i have heard the reviews are bad , but my friend is using one (agp) and is working brilliantly well.
How many kilometers are there from washington Dc to Miami beach?????....
unban praka123!!!....
x3060 is offline
Old 19-08-2008, 12:38 PM   #5 (permalink)
Violent serenity.
Psychosocial's Avatar
Get an NVIDIA 7600GS if ur AGP and Mercury 8600GT if you have a PCI-e slot.
Psychosocial is offline
Old 28-08-2008, 10:41 PM   #6 (permalink)
assasin007's Avatar
thnks guys for caring to help me out.....
i hav an pci-x16 slot.....now can i kno the suitable graphic card n pricing......????
Old 29-08-2008, 11:26 PM   #7 (permalink)
Violent serenity.
I told you, if you have a PCI-e slot get a Mercury 8600GT 256MBGDDR3 which fits in your budget.
Old 30-08-2008, 08:33 AM   #8 (permalink)
toofan's Avatar
Just sell of your machine and buy new one.
Once you are addicted to gamming then you will do the same as I told , then why not to do this right now.
toofan is offline
Old 30-08-2008, 11:14 AM   #9 (permalink)
Excessive happiness
furious_gamer's Avatar
Not everyone can afford to buy a killer machine when they get addicted with gaming...
Consider me, i m working in a sw company and even i cant able to change my machine..
@assasin.
Get a Mercury8600GT which suits ur budget or if spend a lil bit more go for ASUS EN8600GT.....Best buy
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Addicted to Game Dev & Grand Prix Story
furious_gamer is offline
Old 30-08-2008, 11:48 AM   #10 (permalink)
At Hell's Disq
hellgate's Avatar
if u cant affordto buy all the hardware in 1 go then buy it part by part.sometimes when i hafta buy a high end mobo or card and some other stuff and if i dont hav the full amt needed then i buy part by part.
hellgate is offline
Old 30-08-2008, 12:23 PM   #11 (permalink)
Excessive happiness
But thats is not possible to get a Mobo which support Nehalam?
And may be DDR4 get into the game where we just use old DDR2/3..
I hope u get my point...
Old 01-09-2008, 06:54 PM   #12 (permalink)
assasin007's Avatar
thnks guys......
i think m gonna upgrade my RAM to 1 gb n then get a decent card like Mercury which u specified... thnks a lot
Old 02-09-2008, 12:43 AM   #13 (permalink)
Violent serenity.
^2GB minimum as of now . Sorry to make you spend more but its today's minimum. 2GB ATLEAST. 8600GT is a good budget card, you cant go wrong with it .
Old 02-09-2008, 03:47 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
You'll be ok with 2GB, Mercury 8600GT is best for you, and you'll be set to play games with medium-low settings(you won't get the eye candy, sorry) for another 1-2 years.
Till then save some bucks, then you'll have a plethora of comp. configs to choose from(I'm sure of that)
comp@ddict is offline
Old 02-09-2008, 06:29 PM   #15 (permalink)
At Hell's Disq
hellgate's Avatar
so wat ru tryin to prove?
hellgate is offline
plzzzzzzzzz.......help meee.... baadalali772298 Software Q&A 4 28-01-2007 01:18 AM
help guys....? LEARNER_LEARNER Open Source 4 21-12-2006 01:33 PM
Guys help me buy a new pc.... huzaifa b arab Hardware Q&A 2 12-07-2006 04:11 PM
Help me guys ?? tinku dhar QnA (read only) 3 16-10-2005 02:29 PM
plzzzzzzzzz help me!!!!!!!!! sagar_mutha QnA (read only) 7 30-09-2004 12:52 AM
