| Forum |
#1 (permalink) |
Indidiot
http://www.newegg.com/Product/Produc...82E16834115486 http://www.newegg.com/Product/Produc...82E16834210015 |
#2 (permalink) |
you can also take a look at
HP dv9000 series dell inspiron 1730 or Acer Aspire AS7720-6381 to the one u shortlisted
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va |
#3 (permalink) |
Indidiot
Looks I need to make myself more clear. As u can see from the specs, I want:
#4 (permalink) |
yeah thats better for people to give suggestion
#9 (permalink) |
Indidiot
Friends,People and Foru-m-en,
Take a look at the config below and tell me is it worth 65K, that's the price KMD has quoted. Intel Core 2 Duo P8400(2.26GHz) 15.4" Wide XGA 4GB Memory 250GB HDD 5400rpm DVD Super Multi NVIDIA GeForce 9600M GS The GPU has 1GB of its own dedicated memory ! Check the link for product details. http://www.newegg.com/Product/Produc...82E16834220340 ![]() Last edited by Plasma_Snake; 20-08-2008 at 02:50 PM. |
#12 (permalink) |
The Smaller Bang
Dell Studio 17 is perfect for you. Its 17", meaning BIG, as in desktop replacement. And you get Radeon HD3650 DirectX 10.1 capable card which is quite worthy enough to play crysis. You can upgrade CPU to T8100 for gaming. And you get all those value added extra features like finger print scanner, highr resolution, backlit keyboard, etc as upgrades.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#13 (permalink) | |
Violent serenity.
Go for it. You cant wrong with ASUS and the config is damn good for the price and peroformance. ASUS ftw......
Registered pwner of theists, noobs, posers and emos. |
#14 (permalink) | |
The Smaller Bang
its AWSSOME, but if you don't get it, buy Studio 17.
#15 (permalink) | |
Violent serenity.
#16 (permalink) |
Indidiot
Before I place the order just wanna know 2 things, with the small screen size of 15.4" and 17" will the difference between 720P and1080P(in case of Dell Studio 17) is gonna be much noticeable or not? Lastly out of the 2 which one is better 9600M GS or HD3650 coz remember this that the laptop with 9600M GS has max res. of 1280x800 whilst if I go for Dell Studio 17 then the screen will be Full HD. The games then would be played at their max. BUT I don't intend to play that much on the Laptop just few games like GTA 4, Mass Effect, PoP,NFS-Undercover etc NO CRYSIS !
#17 (permalink) |
Lets Do It!
Yes the difference will be noticeable.(720p vs. 1080p)
And yes ... Dell Studio 17 is full HD. HD 3650 is comparable to 8600GT ... And the 'm' versions of both would be less performing ...But 9600m GS should be the clear winner. I would go with the NewEgg one .... If gaming is my priority. And Dell Studio 17 ... For all round entertainment .. (HD 3650 wouldn't disappoint .... U still will be able to play the mentioned games)
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled." |
#18 (permalink) | |
Violent serenity.
#19 (permalink) |
Point Blanc
the resolution is not due to graphic card but due to screen max resolution support.
and as per my thinking 1280x800 is good for 15.4 screen. 1400x900 will be very small. 1600x1050 unusable. Get 17 inch screen and then u can say 1600 is some good. 720p is good on 1280x800 res, but for full HD u wud need 17 inch or more screen sized laptop. Oh I had forgotten something, laptops and the GPU for them mostly come with dual monitor support, so if u got any HD content and wanna see it. just attach a HD capable screen and move ur movie to see onto it. putting money in 17 inch lappy for ultra gaming is foolishness whoever negates me is a fool, but 17 inch for lil bigger n better screen. using laptop for such use is not much of a good idea, first it is so compact and making it overheated not much of good idea. Last edited by acewin; 20-08-2008 at 11:59 PM. |
#20 (permalink) |
Indidiot
So last final words, go for the Asus one as:
#21 (permalink) | |
dont know why they omit to mention this info.
#22 (permalink) | |
Violent serenity.
Buy it eyes closed (keep them open if you want to
#23 (permalink) |
Save the WORLD !!!
Check out the DELL series.... I guess you shoud get a damn good config in Inspiron for 60k compared to XPS..But XPS is really cool in looks 2..Neverthless the configuration that dell provides for any price,i don't think any other manufacturer provides that..
So check it out
Save the WORLD |
#24 (permalink) |
Indidiot
Well its final that I'll go for the Asus one, just waiting for a green signal or u can say waiting for the greens from my folks. Although i can buy it on my own but thten that would eliminate my whole upgrade money saved by me so I'm just gonna pester my dad for it and sooner or later he's gonna crack up.
#25 (permalink) |
Caballero de Real Madrid
buy it from india ... dell studio....
buy the US one only if u plan to use ur laptop as desktop replacement...which is not the case i suppse..coz u referred to a desktop upgrade.... if ur laptop is gonna be ur no1 then i suggest plont more money into it buy a very good one...coz this config u say will be purely updated in 6 months literally...coz of all the architecture changes that will be coming...come 2009 mid..u will be heart broken... again if laptop is ur top prio..i suggest invest some more money into it....buy the best possible u can... or the one is quite sufficient in todays terms....but hey a xps from india for 55k can do these things also very well... just my tuppeny
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS| |
#26 (permalink) | |
The Smaller Bang
And 9600GS is faster by maximum 25% margin over HD3650, and even that, I have seen contradictions against in some reviews. If you buy a Dell Studio 17 from US, like you are planning to buy that ASUS book, I am sure you would end up getting a much better deal since it can be coupled with a much stronger processor and all that for a much cheaper price compared to that in India.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Locate Laptop - locates your stolen laptop! | parthbarot | Technology News | 11 | 16-03-2008 11:29 AM |
| MOST EXPENSIVE LAPTOP - Luvaglio announces world’s most expensive laptop | techtronic | Technology News | 1 | 27-03-2007 02:19 PM |
| Laptop Lan Config error work only with laptop not with pc | minniawochat | PC Components / Configurations | 4 | 19-09-2006 03:21 PM |
