| Forum |
#1 (permalink) |
can any one help me sort out this problem every time i turn on my computer the first 5 mins my montior screen shakes vigorously n den settles down . dis is a hardware problem right? is it a problem wid my monitor? my speakers are away from the monitor(previously dis was a cause to this problem)but still the problem is persisting. plz help thnx |
#2 (permalink) |
The Smaller Bang
problem with monitor. get it fixed/replaced if warranty is still on.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#3 (permalink) |
or time to recycle it
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va |
#5 (permalink) |
This probably won't help unless you're an electronics techie, but just for clarification, this is probably what's happening:
(I'm assuming that you're using a CRT monitor as those symptoms are unlikely to happen with an LCD). CRTs are sensitive to electromagnetic fields, including the earth's magnetic field. When power is off, stray magnetic fields may leave a semi-permanent effect, causing undesireable effects on the colour or picture geometry. When you first switch on the monitor, a powerful alternating magnetic field is generated in a coil surrounding the picture tube for a brief moment to erase the effects of any stray magnetic field. An effect of this erasing field is to violently shake the visible display. Normally, power to the coil is automatically reduced after a second or so, and by the time the tube has warmed up and the POST screen appears, the effect has disappeared. The electronic circuit that regulates the strength of current flowing into the coil may be defective, causing the electromagnetic field to stay high longer than it should. If this is the case, it is not a difficult repair job for a competent technician. A second possibility is that the main filter capacitor in the monitor's power supply has grown weak and cannot do the job properly until it has warmed up. Here the solution is to replace the capacitor. Another easy job for someone who knows what he's doing. Theoretically, the second possibility can also happen with an LCD monitor, though I haven't come across such a case so far. Last edited by pimpom; 18-08-2008 at 02:50 AM. Reason: Spelling typo correction |
#7 (permalink) |
damn busy...
MSI GX660 with ATI 5870 Dell Studio 15(1555) 1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+ www.techjunkiez.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Wide screen monitor | joe2005 | Hardware Q&A | 3 | 13-03-2008 03:45 PM |
| Monitor screen shakes at random | anubhavj1 | Hardware Q&A | 8 | 10-01-2007 10:12 AM |
| shaking display | rounit | Hardware Q&A | 8 | 28-08-2006 06:19 PM |
| Monitor screen shaking!! | krish | QnA (read only) | 7 | 26-06-2005 12:04 AM |
| monitor screen | mohit sharma | QnA (read only) | 2 | 27-01-2005 10:34 PM |
