Old 17-08-2008, 12:45 PM   #1 (permalink)
Unhappy inconsistent DVD palyer!!
Hi I have a sony DVD-RW bought abt a year ago. After having done a fair amount of writing and reading my player is showing signs of disordering---- may be I am too early to judge this.The problem is that I usually write all my movie DVDs at full speed(18X) and my softwares DVDs at abt (8X-12X), but now what i am able to see is that some of my softwares DVDs aren't being read well means my computer si showing a blank DVD whenever insert some (selected) DVDs whereas any external DVD not burnt by the same writer are just fine to be read, I mean they work absolutely fine...
can anybody tell me what mwy be the problem??
uday006 is offline
Old 17-08-2008, 01:23 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: inconsistent DVD palyer!!
^^Might be a lens problem. Clean your lens and see. If not buy a new DVD-RW drive .
Psychosocial is offline
Old 17-08-2008, 01:47 PM   #3 (permalink)
Lets Do It!
amrawtanshx's Avatar
That happens .
Thats why ... Write ur CD's and DVD's @ medium speeds.
So that they are readable later too.
And the lens dont have much life either.
If u do lots of reading and writing ... Then get a new one.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 17-08-2008, 02:08 PM   #4 (permalink)
Violent serenity.
^Thats what I said .
Old 17-08-2008, 02:12 PM   #5 (permalink)
Lets Do It!
I said that since he was writin @ max speeds .... I mentioned this earlier ...Thats why DVD's werent been read by his writer later .... And this prob had the same soln. which both of us knew.
Any conflicts ????
Old 17-08-2008, 02:16 PM   #6 (permalink)
Violent serenity.
All in all buy a new writter.
Shrinking mp3 for my mp3 palyer in linux baccilus Open Source 7 18-07-2008 08:24 AM
mp3 palyer upto Rs.4000 of 1 GB memory!! kool Mobiles and Tablets 2 25-12-2006 06:19 PM
HELP!!!! Windows Media Palyer Error!!! sam_1710 Software Q&A 8 08-05-2006 03:47 PM
