Old 16-08-2008, 08:08 PM   #1 (permalink)
Default Can a DVD Writer read and burn CDs too?
Can it?.Please recommend one within 1.5-2k.
Count Dracula is offline
Old 16-08-2008, 08:21 PM   #2 (permalink)
Lets Do It!
amrawtanshx's Avatar
Default Re: Can a DVD Writer read and burn CDs too?
Yes it can.
Get a Lite On one or Samsung one.
Both are less than 1.5k
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 16-08-2008, 08:45 PM   #3 (permalink)
Exact price and model?
Old 16-08-2008, 09:31 PM   #4 (permalink)
harryneopotter's Avatar
ask for SAMSUNG 22x SATA DVD RW ... dnt pay more than 1100 bucks.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 18-08-2008, 05:04 PM   #5 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
lite-on is the best one and in your budget......
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 18-08-2008, 05:10 PM   #6 (permalink)
Thumbs up Re: Can a DVD Writer read and burn CDs too?
Yes Bro it can... you can go for any of DVD RW they all are now within 2k... but
u should go with the one whose service center is nearby to u...
Cheers
IDontKnow is offline
Old 18-08-2008, 05:19 PM   #7 (permalink)
Lets Do It!
Now LiteOn makes for MoserBear.
They cost 1100 INR ... And the SATA DVD Writers cost 1200-1300 INR.
Dvd writer not able to burn CDs? roonie Hardware Q&A 1 02-02-2008 09:39 PM
DVD writer doesn't read CDs well adithyagenius Hardware Q&A 7 08-06-2007 06:39 PM
DVD Writer Read Problem in XP klerajay Hardware Q&A 2 21-04-2007 10:00 AM
Burn failures with Liteon SHM-165H6S writer stiffler Hardware Q&A 2 03-01-2007 08:40 AM
Burn Cd using DVD Writer? adorablesrini QnA (read only) 3 29-08-2004 10:47 AM
