Old 16-08-2008, 07:26 PM   #1 (permalink)
ninad_mhatre85's Avatar
Default mobo issue ...
hi
today i was using my PC and suddenly it went off monitor was on CPU was On but nothing on screen so i removed plug and plugged in again but no ram beep at start ... so i removed one of my 1gb ram chip from one DIMM slot and started again it worked i changed ram with same slot it again worked but when i changed slot it did not work so i moved to another pair of DIMM slot there it worked but PC never booted ... what could be the problem ??
i am using JETWAY JM2A692-GDG mobo .brought it yr back. i read its manual i came across this but i am not getting what are they trying to say
For the DDR SDRAM CLOCK is set at 400MHz, use only DDR2 800- compliant DDR2
Modules. When this motherboard operate at 400Mhz, most system will not even boot if
non-compliant modules are used because of the strict timing issues, if your DDR Modules
are not DDR2 800-compliant, set the SDRAM clock to 200MHz to ensure system
stability.
also if change/replace my mobo do i have to install all OS`s again ??
Life is not measured by moments u breath but by the moments that take ur breath away
ninad_mhatre85 is offline
Old 17-08-2008, 12:52 AM   #2 (permalink)
Default Re: mobo issue ...
Since your RAM worked with your motherboard before, the working/non-working experience you had was probably caused by improper contact at the RAM slots, not by RAM timing. For the time being, I won't try to explain what your mobo manual says. As for your closing question:
In many cases, no. If you replace your mobo with a different model, you will just have to install the mobo driver again. However, there may be cases where a previous driver installation conflicts with the new one and the previous one has to be uninstalled first before installing the new one. If that turns out to be a hassle, it's best to install the OS from scratch again.
pimpom is offline
RAM Issue... nkparsana Hardware Q&A 4 27-06-2008 03:10 PM
APC - UPS issue sam9999 Hardware Q&A 8 29-12-2006 12:21 AM
RAM Issue speedyguy Hardware Q&A 13 20-01-2006 06:11 PM
RAM Issue.. dreams QnA (read only) 9 25-12-2005 06:44 PM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
