Old 16-08-2008, 12:33 PM   #1 (permalink)
Default Mobo for E7200
Hi,
I had recently bought a HD 3650 gfx card ( http://www.newegg.com/Product/Produc...82E16814102725 ) and g-skill 4gb ram ( http://www.newegg.com/Product/Produc...82E16820231122 )
Now i need to buy the following items :
Proccy( intel E7200)
Mobo
HDD (will buy WD 650gb)
PSU ( coolermaster 460w)
Im pretty confused regarding the mobo, Abit IP35-E seems to be a good choice but some ppl say it is already outdated and it has got only pci-e 1.0 slot. Will it be a constraint in the future when i upgrade my gfx card?( say 1andhalf yrs from now, but i wont go for crossfire). Even my current card hd 3650 is pci-e 2.0.
While AMD has a rock solid mobo with 780g chipset, searching for a non-intel branded mobo for intel proccy has been a pain so far.
I am planning to overclock E7200 to 3ghz, hence the mobo should have good overclocking capabilities.
Can u suggest an alternative mobo if i cant get IP35-E or Biostar TP35. My budget for the mobo is 5 to 5.5k. MSI's p45 mobo seems to be priced > 6k.
Thanks in advance.
p.s- any1 here bought IP35-E from ritchie street?
shailuwap is offline
Old 16-08-2008, 04:38 PM   #2 (permalink)
Point Blanc
Default Re: Mobo for E7200
most of the good mobos are old, there has been bios upgrade and removing of malfunctioning. Do not decide things for future now, like "I wont go for crossfire", I think everyone would get what costs less and is best vfm.
I see on techshop.in there is Palit mobo based on P35 chipset in 4.5K, or Biostar TP35 is also good.
acewin is offline
Old 16-08-2008, 06:04 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
Get Biostar TP35 OR extend your budget and get a Galaxy 680i for 5.5k-6k. The 680i is one hell of an overclocker.
Psychosocial is offline
Old 16-08-2008, 08:04 PM   #4 (permalink)
Galaxy, milkyway they all sound gr8 but hard to find in ritchie street.
I went to ritchie street today and found only one shop having IP35-E for 5.6k.
None of them have heard of Biostar and when i asked for gigabyte G33 one guy replied "Sorry sir, we dont have such high ends mobos"
After enquiring, now its between 3 mobos
Abit IP35-E for 5.6k
Gigabyte G33 for 4.7k
Asus P5Q-VM based on G33 chipset.
I nearly decided on IP35-E when these 2 mobos confused me. Moreover its 1k costlier. Any noticeable benefits? your views please..
Old 16-08-2008, 08:06 PM   #5 (permalink)
Violent serenity.
LOL
Get Abit IP35e as you dont need a onboard. Abit is still great.
Old 16-08-2008, 08:18 PM   #6 (permalink)
Lets Do It!
amrawtanshx's Avatar
ABit IP35 E .... for 5.2k
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 16-08-2008, 08:35 PM   #7 (permalink)
LOL
Its costlier here.. costs 5.6k.
Since i would be paying a premium of 1k for a bit old mobo, just wanna know the benefits.
Everywhere in the forum they recommend IP35-E and they would have had a reason.
umm..can anyone highlight the differences?
Old 16-08-2008, 08:37 PM   #8 (permalink)
Violent serenity.
IT's the best VFM P35 board. Its priced correctly at what it offers. It has plenty of features plus it overclocks very, very good. Its performance matches some of the higher and costlier P35 board. It's the way to go for you right now.
Old 16-08-2008, 08:55 PM   #9 (permalink)
Lets Do It!
Even @ 5.6k .... Its a good deal.
DG965RY supports E7200?? iHATEdigit Hardware Q&A 8 10-08-2008 04:33 PM
E7200 temp issue Fahd.Malik Hardware Q&A 6 08-08-2008 10:51 PM
Overclocking E7200 and OCZ Ram on IP35-e ratedrsuperstar Overclocking 3 22-07-2008 10:19 AM
Suggest Motherboard for Core2Duo E7200 blackbird Hardware Q&A 5 20-07-2008 01:59 AM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
