Old 15-08-2008, 11:26 AM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default HDD
Hi Friends,
I Have The Following PC Config:
Processor : Intel Core2Duo - E4500
MotherBoard : Intel D946GZis
RAM : 1GB DDR2 667MHz
HDD : Currently 160GB INTERNAL & 80GB EXTERNAL BOTH + 240
I am Planning To Buy An 500GB HDD.
Will My PC Support 500GB HDD?
VarDOS is offline
Old 15-08-2008, 12:11 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: HDD
There will be no problems with another HDD on your system as long as there are free SATA/PATA ports available and enough power is present to run the hardwares.
debsuvra is offline
Old 15-08-2008, 03:13 PM   #3 (permalink)
Default Re: HDD
you didnt mentioned the single most important components that could decided whether it will be sufficient to run the HDD to be added and that is the power supply
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
Old 15-08-2008, 05:43 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
I have 400W PSU.
But I Want To Ask That
Will My PC Speed Decrease??
VarDOS is offline
Old 15-08-2008, 06:20 PM   #5 (permalink)
Lets Do It!
amrawtanshx's Avatar
Default Re: HDD
Your PC will support 500GB HDD.
And if u face noticeable differences in comp. speed ... Add another 1GB stick.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is online now
Old 15-08-2008, 07:05 PM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
Let Me Clear That Currently I Have 160 + 80 GB = 240 GB + 500 GB == 740GB
VarDOS is offline
Old 15-08-2008, 07:36 PM   #7 (permalink)
Lets Do It!
Default Re: HDD
Ya... Thats fine...
If there are free SATA/PATA ports .. there will be no problem.
Old 15-08-2008, 07:40 PM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
So My PC Will No Be Slow???
VarDOS is offline
Old 15-08-2008, 07:51 PM   #9 (permalink)
Lets Do It!
Default Re: HDD
If 740GB is filled properly ... Then accessing the contents will be slow.
So for better experiences add another 1 GB RAM.
Old 15-08-2008, 10:24 PM   #10 (permalink)
Default Re: HDD
n dont create too many partitions
realdan is offline
Old 16-08-2008, 09:56 AM   #11 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
Are There Any Side Effects Of Creating Too Many Partations
VarDOS is offline
Old 16-08-2008, 10:11 AM   #12 (permalink)
Point Blanc
Default Re: HDD
I do not think anything will be slow, just like that.
There is something called management.
Your system performance will generally depend on primary drive on which OS is there or which is in use for playing games or watching movies.
which drives are in use i.e if you are doing data transfer.
In short no need to really worry.
Rest people ahve already said or asked like PSU wattage(400W good enough for running 4-5 HDDs also with the config you got, you have low power consuming config) and how much each HDD is filled. and no of availability of SATA/PATA ports
Check your power consumption from http://www.extreme.outervision.com/p...ulatorlite.jsp
I saw realdan has mentioned about partitions, Varad, partitions are for managing your HDD(not physically but logically), and yes more partitions would decrease performance
acewin is offline
Old 17-08-2008, 10:25 AM   #13 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
Even If I Add One More 1GB Stick. Then Also The Performance Will Decrese.
In Total Now I am Having C:/, D:/, E:/, F:/, G:/,H:/ All Are 40GB's. The Last Two Are Of My External HDD. Can You Tell Me Howmany Partitions Are Created Standerdly In 500GB. Iam Planning To Create The Partation 80GB Each. Insted Of 40GB. Of My Present HDD. So That There Will Not Be Too Many Partations. What Do You Think?
Thank You
Varad.
VarDOS is offline
Old 17-08-2008, 10:30 AM   #14 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: HDD
Your PC will easily support it and there will be hardly a slowdown. I suggest that you better get a Western Digital Caviar 640GB instead of 500GB. It's the most VFM HDD right now.
Psychosocial is offline
Old 17-08-2008, 12:08 PM   #15 (permalink)
Lets Do It!
Default Re: HDD
Ya ....WD 640GB is the most VFM HDD.
But after having nearly full HDD's ... Accessing the contents will surely be slow.
Thats why I recommended to add another 1GB stick.
After that .... Performanc will be fine.
Old 17-08-2008, 12:44 PM   #16 (permalink)
Violent serenity.
Default Re: HDD
^^I didnt said have an objection with you recommanding 1GB of more RAM. More RAM is always better than having less RAM
Old 17-08-2008, 01:01 PM   #17 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
Now I Am Having 1GB RAM. Wat Do You Tell Should I Sell This RAM. And Buy 2GB RAM.
Or Add One More 1GB Stick???
__________________________________________________ ______________________
Also Visit My Site
http://askvarad.blogspot.com
VarDOS is offline
Old 17-08-2008, 01:03 PM   #18 (permalink)
Lets Do It!
Default Re: HDD
Thank You
Varad.
Dont worry too much.
After adding 1GB RAM u wont be dissappointed.
Just take care of the partitions ... I mean dont make too many
2*1GB performs better than single 2GB stick.
So I think u get the point.
Old 17-08-2008, 01:13 PM   #19 (permalink)
Violent serenity.
Default Re: HDD
Get one more stick so that both runs in dual channel providing better performance. (Seeing that your mobo supports Dual-Channel, check your Mobo specs and tell us if it supports dual-channel or not ).
Old 17-08-2008, 01:17 PM   #20 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
So Totally My HDD Wil Become 880GB. I Asked My Computer Vendor He Is Telling Don't Go For WD In Spite Go For Seagate Because NoBody Is Using WD In Our Town & Also WD Is Not Avliable In Our Town.But I Saw HDD's On The Net n I Liked It. So Can Anyone Tell Me The Price Of WD 640GB HDD.
VarDOS is offline
Old 17-08-2008, 01:21 PM   #21 (permalink)
Violent serenity.
Default Re: HDD
^Its 3.6k and tell ur vendor that WD is one of the best ... err .... THE BEST HDD BRAND. GO for it . ITs great VFM. If you cant get it retail, get it from online shopping stores.
Old 17-08-2008, 01:24 PM   #22 (permalink)
Lets Do It!
Default Re: HDD
Its for 3.7k.
But since the service center is not in your town ... U should better go for Seagate ...
Seagate's service is pretty good and replacement takes only 3-4days.
Old 17-08-2008, 01:24 PM   #23 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
Next Week I am going to Mumbai can anybody tell me the shop where i can get the HDD??
VarDOS is offline
Old 18-08-2008, 10:40 AM   #24 (permalink)
Point Blanc
Default Re: HDD
Varad, add one more stick of 1 GB it would be OK. In 640 GB make not more than 4 paritions. But if you wanna maek more partitions I hope you know how to make it in XP.
Keep partition sizes big like 200 GB according to your data and how you wanna group them.
Check in the local market, and if they do not give your good price then buy from online site the price is 3600 now, maybe drops more by the time you go n check. heehe
acewin is offline
Old 18-08-2008, 02:41 PM   #25 (permalink)
Violent serenity.
Default Re: HDD
When I had 250+750 (Now the 750 aint working ), I made only 4 partitions from the whole 1000GB . 1 for Windows OS (any), 1 for Linux (later turned it for XP as the other was used for Vista) [Both of this were on 250GB and each was of 25GB]. The other 200GB for data and one whole 750GB partition for data. I dont prefer more partitions :.
Old 19-08-2008, 01:50 AM   #26 (permalink)
Point Blanc
Default Re: HDD
generally if you defrag your partitions regularly to reorder them, then access of data from the partitions does note gets as much slowed down.
acewin is offline
Old 19-08-2008, 10:15 AM   #27 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
Recently While Surfing On Some Sites I Came To Know About SATA, eSATA, Sata2 What Is That Can Anybody Tell? And I Also Don't Know Which Is My Present HDD. Can Anybody Tell How To Know That?
VarDOS is offline
Old 19-08-2008, 12:08 PM   #28 (permalink)
Violent serenity.
Default Re: HDD
Serial Advanced Technological Attachment (SATA).
Its the most used HDD technology right now and you should go with it. WD Caviar 640GB is SATA.
SATA2
Newer and a little faster but less used and less supported.
eSATA
external SATA for external HDDs.
I dunno which HDD you are using. Can be PATA or SATA or IDE.
Stick with the above mentioned HDD and you will be fine.
Old 19-08-2008, 12:28 PM   #29 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: HDD
My Current HDD Is SATA. I Have Seen This In My MotherBoard Features:
Peripheral Interfaces Eight USB 2.0 ports
One serial port
One parallel port
Four Serial ATA interfaces
One Parallel ATA IDE interface with UDMA 33, ATA-66/100 support
One diskette drive interface
Can AnyBody Tell Me How Many Sata Ports Currently Iam Having?
And Can I Add One More HDD?
VarDOS is offline
Old 19-08-2008, 12:33 PM   #30 (permalink)
Violent serenity.
Default Re: HDD
^^Its writtedn that there are 4 SATA ports clearly
So you can add three more SATA HDDs.
