Old 15-08-2008, 12:52 AM   #1 (permalink)
harryneopotter's Avatar
Default Zeb 8600GT,showing ill signs..help.
Hi guys ..
I have Zebronics 8600GT installed on ASUS M2NPV VM board. I was away from delhi since monday and when i came back today the System was showing Display probs like.
Distorted Display at Boot Time motherboard LOGO..
Numerous Triangles at bios screen
4-5 groups of 5-6 blue vertical line at OS Choice Menu(Vista-XP) placed at regular intervels.
My card doesnt have a VGA port and my LG 17" CRT (700E) doesnt have DVI input so i am using a DVI-VGA Adapter to connect them. When i connecte the CRT to the onboard VGA, its working fine.
Is the Graphic card has come to its end ??
It was bought in May 2007 (it has a sticker with the month and year marked on it) and i dnt have any bills for it. Am I eligible for RMA if its indeed gone kaput? or cleaning it thoroughly and the placing it again,will do the trick ? (As there is lot of dust on it)
Plz help guys.
Thnx.
Sachin
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 15-08-2008, 03:09 PM   #2 (permalink)
Default Re: Zeb 8600GT,showing ill signs..help.
so have u cleaned it if not cleaned up not only the graphics card but also the ram connections etc..and at least touch some metal surface before handling the components and held them at the edges and dont put your hands all over it
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
top 10 signs ur kid is a hacker RaghuKL Chit-Chat 3 06-02-2008 12:14 PM
8600GT 256MB or 8600GT 512MB? Sreeejith Hardware Q&A 53 29-10-2007 07:54 PM
8600GT or 8600GTS or 8600GT Fatality bajaj151 QnA (read only) 31 12-08-2007 08:38 PM
Top 5 signs of mobile phone tapping kill_deep_singh Mobiles and Tablets 2 17-02-2006 04:16 PM
Hdd signs ! ! ! ax3 QnA (read only) 15 12-08-2005 08:08 PM
