Old 14-08-2008, 10:31 PM   #1 (permalink)
Question where is my ram ???
i have one Kingston DDR2 RAM 1 GB 667. (OLD)
i bought another 1GB DDR2 RAM of Kingstom 667.(NEW BOUGHT TODAY)
when just the 1 GB is connected (OLD RAM or NEW RAM) it shows 896 mb of RAM.
BUT when both are in the slot then the system property still shows 896MB RAM.
Pc config:
Pentium D 2.8
D102GGC
Why is this happening ???........Is new ram is not compatible ( if yes ,then why) ???....
kushal_7 is offline
Old 14-08-2008, 11:58 PM   #2 (permalink)
Default Re: where is my ram ???
as per http://www.intel.com/products/mother...GGC2/index.htm
if it is the exact model then it couldnt run at 667 so it will run at 533..
there are only two slots of memory it seems it doesnt support 1gb in 1 slot and 1 gb in 1 slot according to the technical product specification http://www.intel.com/support/motherb.../CS-029352.htm as there are no mention of the same there.
check your memory section in the motherboard manual
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
Old 15-08-2008, 12:31 AM   #3 (permalink)
in my PC 1 Gb ram of 667 is working fine.......but both (acc to specification) are not......so what should i do now ???......should i buy the ram of diff freq (lower ) ( ithink in that case there is freq mismatch) or simply i can't upgrade my RAM....
kushal_7 is offline
Old 15-08-2008, 02:57 PM   #4 (permalink)
well according to document spec..it should support upto 2gb memory. spelt out both of your memory model no. to see if the memory experts here can figure it out
realdan is offline
Old 15-08-2008, 05:06 PM   #5 (permalink)
[ DIMM1: Kingston 1G-UDIMM ]
Memory Module Properties:
Module Name Kingston 1G-UDIMM
Serial Number 38245B5Ah
Manufacture Date Week 12 / 2008
Module Size 1024 MB (1 rank, 8 banks)
Module Type Unbuffered
Memory Type DDR2 SDRAM
Memory Speed DDR2-667 (333 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 333 MHz 5.0-5-5-15 (CL-RCD-RP-RAS)
@ 266 MHz 4.0-4-4-12 (CL-RCD-RP-RAS)
@ 200 MHz 3.0-3-3-9 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Supported
Auto-Precharge Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Memory Module Manufacturer:
Company Name Kingston Technology Company, Inc.
Product Information http://www.kingston.com/products/default.asp
[ DIMM2: Kingston (1 GB DDR2-667 DDR2 SDRAM) ]
Serial Number 8D327BE7h
Manufacture Date Week 3 / 2007
Module Size 1024 MB (2 ranks, 4 banks)
Module Width 64 bit
Memory Timings:
kushal_7 is offline
Old 15-08-2008, 06:30 PM   #6 (permalink)
Lets Do It!
amrawtanshx's Avatar
Your board supports DDR2 533MHz and DDR2 400MHz DIMMs ... Upgradable to 2GB.
Thats why they aren't compatible.They are 667MHz.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 15-08-2008, 11:21 PM   #7 (permalink)
but my frnd i am asking that how my board supports the 1 gb ddr2 667 ram ????.........
kushal_7 is offline
Old 17-08-2008, 08:46 PM   #8 (permalink)
it could be this...the two ram are different as one Module Size 1024 MB (1 rank, 8 banks) and the other has Module Size 1024 MB (2 ranks, 4 banks) ..though this could be more an issue in the case of running in dual channel mode..dont know whether the chipset has a limitation in supporting 2gb if the clock speed is underclocked to 533 from 667 or it is of a different make even if you are not trying to run in dual channel...but looks like your motherboard cannot recognize beyond 1gb goes to show that it wont support 2gb memory of 667 speed probably in dual channel becos both chip are different..
maybe it try to run in dual channel mode when connected and sense memory difference so do not recognize the other memory module.
this looks more likely
or it cannot underclocked to 533 from 667 in dual channel
or it cannot underclocked to 533 from 667 when two slots are occupied
realdan is offline
Old 17-08-2008, 09:28 PM   #9 (permalink)
aswin1's Avatar
I think you should check whether your new RAM and RAM slot is functioning properly by removing the older RAM from its slot and booting the PC.
aswin1 is offline
Old 17-08-2008, 10:34 PM   #10 (permalink)
moshel's Avatar
i may be wrong..im just speculating....isnt it so that if u dont have a graphics card installed on the computer, a part of the main RAM is used for video acceleration? probably that is causing the problem...
welll see...
1024-896 = 128...and thats the video ram on this mobo.
moshel is offline
Old 17-08-2008, 11:39 PM   #11 (permalink)
nope i m afraid that is not an issue for him..the problem for him is another 1gb of memory in another slot is not being taken into account by his system.
realdan is offline
