Old 14-08-2008, 09:22 PM   #1 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Exclamation Where's my RAM running away?
Folks, I'm in a great problem, it seems something eating my RAM away, not what you think but the memory size is reducing day by day.
By CCleaner, my RAM showed 512MB.
About a month ago, itcame down to 503MB, I didn't pay any attention.
7 Days back, it came down to 498MB, ok mabe some fault was there.
Now, today, 486 MB, now confirmed something wrong.
Guys,I can't figure out what the problem is, and I cannot simply afford to let this continue, What's the problem??????????
comp@ddict is offline
Old 14-08-2008, 10:27 PM   #2 (permalink)
aswin1's Avatar
Default Re: Where's my RAM running away?
No need to worry CCleaner shows available RAM rest may be used by onboard graphics. Use
CPU Z to check actual RAM.
aswin1 is offline
Old 14-08-2008, 11:41 PM   #3 (permalink)
must be taken away by ccleaner..
seriously right click my computer and properties..and the amount of ram shown there is the one avail to the system
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
Old 15-08-2008, 12:29 AM   #4 (permalink)
Violent serenity.
Psychosocial's Avatar
Right Click on My Computer > Properties.
Check there.
Psychosocial is offline
Old 15-08-2008, 02:01 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well you think I havn't tried that, even that seems to get updated. And I don't have onboard graphics. I have been using a 6200TC for the past 3 years.
Old 15-08-2008, 02:07 PM   #6 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
So its 6200TC. Thats TurboCache and the GPU can use some amount of memory from RAM in addition to its onboard memory if TurboCache is enabled. Maybe thats whats happening. Try CPU-Z.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 15-08-2008, 04:58 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Check using "type dxdiag in run"....how much are you getting.
System RAM can not decrease, unless you are physically replacing the memory modules.
asingh is offline
Old 15-08-2008, 08:24 PM   #8 (permalink)
Lets Do It!
amrawtanshx's Avatar
Use CPU Z to check RAM.
And in any case it cannot decrease.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Dvd Not Running Josan QnA (read only) 4 22-10-2007 05:04 PM
why its not running?????? william Gamerz 7 11-02-2007 02:29 AM
dvd not running sujeet2555 QnA (read only) 3 26-07-2005 10:09 PM
Running Far cry Tommygecko Gamerz 4 26-04-2005 04:52 PM
What are we Running After ? vswizard QnA (read only) 15 10-05-2004 10:17 PM
