i have a budget of rs5000 to buy an external hard disk.what would be the best brand and capacity for my budget?also if i buy a regular internal hard disk & use a casing will i get the same performance?what will such a package cost? please tell me the best possible solution..
he can afford 250 or 320 GB pre-built external drives in 5K.
WD Passport is good, and seems people have also started recommending Transcend's storejet's built, the one with black and orange finish, not the transcend standard casing externals.
can i use an internal 500gb hdd as an external drive? pre built 500gb ext. hdd's need an ac adapter..if i use an internal..will it need a separate power source?
yes, because all desktop hard disk based external drives need external power.
External power supply based external HDDs can be a pain if you need to take external everywhere( hence better internal HDD kept as internal HDD), so better buy laptop HDD based external or slim external HDDs which just run on USB supplied power from the system. Branded external HDDs are real good.
actually i'm not planning to move my HDD around..so a power supply wouldn't be a problem..so how much is a 500gb HDD going to cost in mumbai?how much would a 750gb & a 1TB cost?is there any chance of costs coming down in the next 1 month?
