Old 12-08-2008, 11:01 PM   #1 (permalink)
Default Flashing my BIOS
I have a ASUS M2N SLI Dx Motherboard. Today, when starting my comp, after the POST I was presented with a blank screen, and nothing was happening. There was no light from the HDD LED too. Thinking that Windows had crashed once again I tried booting from my Windows Boot CD. However the BooT CD didn't boot too. I entered BIOS settings and checked that CD-ROM is selected as first boot device. I tried again, but to no avaail. I restarted again, this time pressed F8, to enter boot selection and selected to boot from CD-Rom, but still was stuck at the blank screen. I tried another bootable CD from a friend. Still no joy. In frustration I tried booting from my Open Suse, Mandriva and RedHat Linux CDs, but still no joy. Finally I tried booting to BeOS from my ASUS CD, which came with the motherboard, but still no joy. At this point I realized that my BIOS is simply not handing over control. So I tried flashing my BIOS, with the ASUS Ez Flash utility. However, this effort has come to a nought due to some jumper setting I can't find on my motherboard.
The error I get is
FLASH RoM is write protected
Please make sure whether lockout jumper is set to correct or not.
I can only see two jumpers on my Motherboard. One is the CLRTC jumper to reset the clock and get the motherboard to default settings and another which has CHASIS written beside it.
I am in urgent requirement of help as it is very vital, to my work to get my comp working.
Thank You.
aircombat is offline
Old 12-08-2008, 11:43 PM   #2 (permalink)
Default Re: Flashing my BIOS
restore the BIOS default...have u tried that?
realdan is offline
Old 13-08-2008, 01:35 PM   #3 (permalink)
I had tried restoring both through the options and through the CLRTC jumpers. It was of no help and hence tried flashing my BIOS. Presently the BIOS has got erased, but I can't write the new BIOS file.
Old 14-08-2008, 02:49 PM   #4 (permalink)
uhoh...try taking out the cell battery on the motherboard and insert it back after a min or so
OR
remove all unnecessary components incl optical drives from your PC..and boot from hdd..
by the way how did you try to flash the BIOS...using USB pen drive? or from CD? and what is your original BIOS version as
M2N-SLI Deluxe BIOS 0307 (Please do read the description before updating BIOS)
(Do not use EZ-Flash to flash BIOS if your BIOS version is prior 0307.)
realdan is offline
Old 15-08-2008, 05:52 AM   #5 (permalink)
Try replaceing the bios with new written one through any motherboard expert.
longlife is offline
BIOS flashing ??? ax3 QnA (read only) 9 04-02-2008 10:59 AM
flashing bios vicky_l7 QnA (read only) 8 25-06-2007 10:42 AM
BIOS Flashing Stalker Hardware Q&A 3 18-09-2006 01:16 AM
Flashing the BIOS nishant_nms QnA (read only) 11 25-09-2005 02:33 PM
