my machine is a pentium d 102GGC
BIOS shows a system bus speed of 533MHz
now i have one Trancend DDR2 RAM 512MB which is also 533 MHz. (OLD)
i bought another 1GB DDR2 RAM of Dynet 667MHz.(NEW BOUGHT TODAY)
when both are in the slot then the system property shows 896MB RAM.
when just the 512MB is connected (OLD RAM) everything works fine.
when just the new RAM 1GB is connected then it still shows 896MB and i m facing a lot of hardware issues. LAN card behaving erratically. windows explorer crashing etc.
is it bcoz the RAM is 667MHz and system bus speed is 533Mhz???
to add to it ... i got the 1gb RAM replaced and he gave a different piece same config.
but issue persists!!!
