I seem to be having a strange issue with my computer. I have a 1gb stick that the computer will only read as 512mb for some reason. If I add another, say 256 stick it will read the 256 as full and still only the 1gb as 512. (So 768mb total) I know the stick is 1gb as it works fully in my friend's computer. Perhaps I have something set wrong or such. I'm pretty new to computers and I know my machine is kind of old. I'll put whatever stats I can find below, though I'm not sure what might be needed. Any help or suggestions would be greatly appreciated. Thank you.
Compaq Computer
Presario 6000 (6320?)
AMD Athlon XP 2000+
1.67 Ghz 480mb RAM (currently reading only 480 of a 1gb stick)
Ran a Crucial system scan on my memory and this is what I got:
Currently installed memory:
512MB
EMPTY
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
- Maximum Memory Capacity: 2048MB
- Currently Installed Memory: 512MB
- Available Memory Slots: 1
- Number of Banks: 2
- Dual Channel Support: No
- CPU Manufacturer: AuthenticAMD
- CPU Family: AMD Athlon(tm) XP 2000+ Model 6, Stepping 2
- CPU Speed: 1665 MHz
Keep in mind that although it it saying 512mb, it is a 1gb stick in that slot.
Thanks
