12-08-2008, 02:11 AM
GaurishSharma.com
End of Life of my 3yrs old machine?
My 3year old desky is seems giving up its strulle to live. now every now then i am presented with wierd issues.
1) i can't install arch Linux on it, i get some wierd error related to libata, perhaps sata port is fying slowing but windows is still working without issues.
2) the sceen is black with Graphics adapter plugged in, i am removing it for a while untill i found a solution.
3) The boot time has increased due to some unknown reason, the BIOS hangs for about 8-10secs with a msg "verifying DMI pool Data....".
4) wonder how, but it burned my HDD due to some wire shorting. thanks to Seagates No-Questions-asked return policy, i got a new drive.
5) sometimes POST screen is shown with corrupted graphics.
6) every now and then system refuses to boot, gives me two LONG BEEPS.
then i have to remove-clean-inseart the ram module. it becoming more frequent day by day
AMD ATHLON 64 3000+
MSI K8MM-V
1GB DDR RAM
80GB SATA-II HDD
Nvidia Geforce 6200 128mb
BenQ 1655 DVD writer "Old WIne"
Thouhts on Buying a new Rig,
Well, my work on this machine is limited to email,blogging,forums etc.
so, i am not yet into buying mode.
Please suggestion solution to above problems, if there are any.
else i would have to dump this and stick to my notebook
12-08-2008, 03:11 AM
Re: End of Life of my 3yrs old machine?
+1
12-08-2008, 04:51 PM
All those symptoms could be caused by a single source. My suggestions:
1. Check or replace the CMOS battery
2. Clean all dust inside the cabinet, including the heatsink
3. Remove and reinsert all connectors
4. Disconnect all drives except the DVD drive and run Memtest86
12-08-2008, 05:14 PM
The Smaller Bang
According to my calculation, your rig should live another 2 years minimum. Period.
Do what pimpom said and see if it helps.
Look at my rig in my siggy and tell me if its not weaker than yours. I bought it in Q3 2005. But its perfect even today. Yours is much better than mine in terms of power. It also has better components. When my rig itself looks like its going to last till next year June, why can't yours last for an year more than mine ?
Apple iPad 2 16GB WiFi
12-08-2008, 05:18 PM
The Devil's Advocate
@pimpom +1. Check mobo.
http://beingmanan.com
12-08-2008, 05:30 PM
I share the same story. Your motherboard BIOS is bad and SATA controller is going bad. Its one of the reason why HDD are going bad in my PC.
Some bunch of bad coders left BIOS bug and made controller badly designed.
So just change the mobo to save other parts.
See if changing Mobo helps.
12-08-2008, 05:37 PM
The Smaller Bang
Is that CPU AM2 ?
12-08-2008, 06:17 PM
I agree, unless it is proven that there is something wrong with the mobo. It's easy to be influenced by all the hype we read everyday. As long as an older system does everything we want, there's no need to get a new system just to keep up with others.
That said, I think you'll notice a pleasant increase in performance if you put in another 256 or 512 MB, Metalhead.
I wouldn't think so. Judging from the mobo/chipset used, it's probably a single-core socket 754, and it's plenty fast. Except for video rendering and hardcore gaming with a powerful graphics card, I doubt if anyone will notice any difference from using an X2 6000+ or a C2D.
12-08-2008, 08:15 PM
The Smaller Bang
And thats why I keep my computer even now, without any upgrades. It does the job beautifully, and I need nothing more, since I myself along with my OS have adopted to the environment.
Thats what everyone else says too. And I too think I need 1GB. Mainly because linux is more RAM driven than CPU driven.
But at the end of the day, I am stuck with this system since I never get time to buy a stick of ram
SP Road is far away from my house, and hence I can go only on holidays. But each time, something stops me from going. Be it an examination, a sickness or a visitor. Sometimes, when I am fully prepared, its some state holiday or there is some violence related issue.
12-08-2008, 08:47 PM
I wish such obstacles were the only kinds I face. Why don't you just order them? Like from Computer Warehouse in your city? Their current price for Transcend 1GB DDR400 is 1.8k.
Me, I live in a small city in one of the most remote parts of the country. The nearest major city is 500+ km and Rs.4k away by air, and three times that distance and at least 3 days by surface transport.
12-08-2008, 08:49 PM
IronMan; Ready to Roll...
@MetalheadGautham;
Oh common! Don't fuss like a baby; just go out there and take the plunge.
(Edited)
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
12-08-2008, 09:32 PM
The Smaller Bang
Looking at your plight, I feel like mine is nothing at all
I seriously pity you.
Originally Posted by IronManForever
@MetalheadGautham;
(Edited)
its not as easy as you think. finding free time in non holidays for 6 hours at a stretch to travel and make a purchase can be a pain for a student like me.
12-08-2008, 09:57 PM
GaurishSharma.com
Did everything, now i am able to use my PC via windows Xp. no plans to mess up further.
problems still exists
1) System takes long time to boot
what is this thingy?
2) how do i make sure its my sata port which is dying?, can it be repaired?
Can you say more on your story?
how is the BIOS buggy?, and do you have the same mobo?
Reason: Automerged Doublepost
12-08-2008, 09:59 PM
The Smaller Bang
tried using another sata port for hdd ?
GaurishSharma.com
Is that CPU AM2 ?
its 754pin mobo
this happens on both sata ports
Here is a weird observation.
I am not sure if its the SATA port,software & drivers part, or HDD. more over the problem is random. so troubleshooting it difficult
The sata errors happen only when i use Linux, the system hangs can i get a msg
"ata2.00: status: {DRDY ERR}
ata2.00: error: {UNC}
ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
ata2.00: DMDMA stat 0x5
ata2.00: cmd c8/00:08:06:fd:6e/00:00:00:00:/e2 tag 0 dma 4096 in".
Its random and mostly happens during heavy I/O.
XP also hangs sometimes, but no error message.
Sometimes in Post screen and i get corrupted graphics(green & yellow lines).
12-08-2008, 10:53 PM
Violent serenity.
Your rig will cut it. Change the CMOS battery and do a little dusting. Check your temps. and see if your RAM is faulty. Otherwise it would cut it. If my system can work till next two years, then yours can surely. Happy computing.
12-08-2008, 11:09 PM
Could be your master boot record is corrupted. If you have a DOS boot disk, boot with that and at the command prompt, type fdisk/mbr and press Enter.. That will restore the master boot record. Now remove the boot disk and boot normally again and see if there's any difference.
Also, if your BIOS has a RAID/Non-RAID option for SATA, set it to Non-RAID.
I doubt it, except perhaps at the motherboard company's service center.
Have you cleared the BIOS? I forgot to include that in my first reply.
If all of these (restoring MBR, setting to Non-RAID and clearing the BIOS) do not make any difference, do a surface scan of your C: partition.
12-08-2008, 11:25 PM
GaurishSharma.com
*My HDD is brand new, just 2days old, so corrupted MBR is remote possibility. made partions just yesterday using xp cd. spend many hrs to setup xp(drivers,programs & customizations). i don't want to format again
also, it pauses for a while(7-8secs) and boots. if there was a corrupted MBR then is would simply refuse to boot.
*there is no choice RAID/Non-raid mode.i have to use a Floopy disk to install XP.
*taking it to service center is a option but i find it very hard to explain them my problem. i tried a month back but at service center is ran perfectly fine.
its all random.
*no, i haven't cleared the BIOS yet, will go it after i finish buring a few dvds
RAM is relatively new in my system, purchased it year back.
also i have checked up with MEMTEST86, no errors
ps: what do you mean by cut it?
12-08-2008, 11:38 PM
#19 (permalink)
Violent serenity.
By cut it, i meant it will easily last for 2 years.
12-08-2008, 11:52 PM
#20 (permalink)
He probably means that your config is still good enough, not yet ready for the scrap heap. Remember you mentioned dumping it in your first post.
Another thing: how dry or wet is Jaipur? (I'd guess dry, seeing that you're close to the Thar Desert). Many people experience strange symptoms with their computers in the rainy season, especially with older systems. The accumulated dust retains moisture which in turn provides electrical leakage paths. This can cause havoc with a system.
13-08-2008, 03:18 PM
#21 (permalink)
Point Blanc
for some reason or the other mobo is functioning bad due to ports went wrong or something. Which service center you gave your mobo to.
You say most of the problems r coming booting linux.
Have you tried any other distro. I do not know if it becoming driver issue for Linux, going on that part because you say Service center guys find everything fine.
If u r facing a problem and hey cannot find it after your little explanation also, then the person certainly would be dumbass. They need to chek the circuits and ports functioning, as you are getting errors refering to your port. confguring MBR is really not much of an option it could have been due to bad sectors which as you said is not .
Besides I really would say you should ask how the service center guys are checking it, putting all different hardwares to check( I mean are they putting some different RAMS proccy or what), to know if there is any hardware incompatibility issue.
