Old 10-08-2008, 09:13 AM   #1 (permalink)
hansraj's Avatar
Default suggest me the correct ram for laptop
The follwing are my pc specs and i want to upgrade my memory to 3 GB (as i have heard that having 4 GB in 32 bit XP version has no use.... the max which i can use is 3.2 GB). But it appears that my present ram module is 133 MHz and i want to know if it is better for me to go for removal of this existing module and have 1GB +2 GB module with freq lesser than 533 MHz ( which apparently should be 266 MHz??? any higher till 533 available??). I want suggestions from u all, is my understanding correct? Also if any better solution exists as far as my upgradation is concerned. Thanks.
cpu
memory
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 10-08-2008, 09:19 AM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: suggest me the correct ram for laptop
I think it should be 533. 266x2 is 533MHz RAM.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 10-08-2008, 05:15 PM   #3 (permalink)
hansraj's Avatar
how much difference in speed will it make if i have 3 GB ram with 133 MHz and same with 533 Mhz ? will it be significant or marginal
hansraj is offline
Suggest a LAPTOP under 45K??? jal_desai Laptops and Netbooks 11 05-12-2007 01:58 PM
Suggest laptop for Rs. 40k to 50k ilugd Laptops and Netbooks 1 18-09-2007 11:39 AM
suggest laptop within 50k thadhanihemant Laptops and Netbooks 6 02-11-2006 11:49 PM
Please Suggest a Laptop for 80K freshseasons QnA (read only) 8 20-11-2004 12:03 AM
suggest me correct DVD Media kaysquare QnA (read only) 3 02-09-2004 12:45 PM
