Old 10-08-2008, 12:57 AM   #1 (permalink)
Default Intel D915GAV or Intel Core 2 Duo / Core 2 Quad...!!!
Hi Gurus...I am stuck with what to do.
I have one motherboard brand new kept from last 1 year which is Intel D915GAV.
Option 1: Should I purchase a processor which supports this motherboard and if yes what are the advantages and disadvantages.
Also let me know which processor and whats the price roughly...???
Option 2: Purchase a new Core 2 Duo / Core 2 Quad.
I did a lot of reading but the more I read I get lost.
Can you say me which Intel Processor is good - any model numbers for Core 2 Duo and Core 2 Quad and indicative prices.
Also please indicate the supporting motherboard for this option and how many PATA and SATA hard disks it can hold respectively...???
I know asked a lot but its urgent as I need to make a purchase. really thanks.
regards
sunando
sunandoghosh at gmail dot com
sunandoghosh is offline
Old 10-08-2008, 01:39 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Intel D915GAV or Intel Core 2 Duo / Core 2 Quad...!!!
Intel 915 series support only upto P4. You wont be able to use dual core, C2D and higher processors.
Rest will depend on your use and budget. I mean how will you use your system, and what is your budget??
will depend on the motherboard you select. Generally motherboards have 2 IDE port and 4-6 SATA port.
ravi_9793 is offline
Old 10-08-2008, 09:29 AM   #3 (permalink)
EXcellent point and infact that was one of my concerns...
I use system pretty intensively...in terms of multiple applications and maqny web pages and documents opened simulatenously...
My Budget for Motherboard PLUS Processor (excluding other things) is Rs 12000 - Rs 20000.
Atleast 2 IDE port and 2 sata is bare minimum i am looking forward to...
RAVI - thanks again for replying. Can you please now suggest.
Do u suggest purchasing Core 2 Quad and which motherboard...pls be as descriptive as possible...thanks man
regards
Old 10-08-2008, 11:32 AM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
http://support.intel.com/support/mot...sktop/D915GAV/
http://www.intel.com/products/chipsets/915g/index.htm
it looks decent for an old board.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 10-08-2008, 01:49 PM   #5 (permalink)
dOm1naTOr's Avatar
U can get a Q6600 and abit IP35-E for 14k total. It wud suit ur need and budget perfectly...
getting a proccy for that 915 is not a good idea.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 10-08-2008, 03:01 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
regards
Sorry I am not in touch with hardwares these days.
Old 10-08-2008, 03:18 PM   #7 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
get this
if u can spend ~2000 more get an aftermarket cooler for this processor
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 10-08-2008, 03:50 PM   #8 (permalink)
Tux Fan
shaunak's Avatar
Since gaming dosnt seem to be you primary objective,Idd suggest a dual core processor:
*Intel DP35DP (5.5K) + E7200 (5K) +Gfx Card (3K to 44K , depends on you.)
note: The mobo has great onboard sound capabilities
If you need a bit more power:
* E8200(8K) + Intel DQ35JO(6K) [Board has onboard gfx soln]
Links:
*http://www.intel.com/products/deskto...o-overview.htm
*http://www.intel.com/cd/channel/rese...ture/index.htm
*http://processorfinder.intel.com/det...px?sSpec=SLAVN
*http://processorfinder.intel.com/det...px?sSpec=SLAPP
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 10-08-2008, 04:32 PM   #9 (permalink)
The Smaller Bang
wrong. q6600 is 9k and ip35-e is 5.5k. totals to 14.5k. plus 1.3k for basic 7100gs gpu.
since not into gaming, better get XFX 630i GF7150 mobo for 3.5K. total with q6600 is 12.5k.
OR, get Phenom X4 9550 for 7.5K plus 780G board for 4.5K total 12K. this has the best onboard gpu which can effortlessly handle HDTVs.
I doubt you need to raise your budget to 20k for getting a heavy multitasking mobo/processor. This is not 2006.
Old 10-08-2008, 08:47 PM   #10 (permalink)
Smile Re: Intel D915GAV or Intel Core 2 Duo / Core 2 Quad...!!!
Originally Posted by MetalheadGautham View Post
Yes but now based on all feedback I am thinking of going for Core 2 Quad Option...May be i am thinking of buying one P4 processor for it to give it to my small cousing brother / sister...
My Biggest Fear: I am a very heavy computer user but not a techie...so really does not know in detail motherboards...but always in last few years trusted INTEL as I believed that i will not at least be making a bad choice if not the best choice...
I am convinced about Q6600 BUT very sckeptical about ABIT IP35-E (infact heard it first time).
I want really a motherboard which is premium brand with atleast 2 IDE 2 SATA and decent inbuilt graphics card (I know graphics card is required but dont know how much is good and whats optimum there vis a vis cost)
Never mind Sir...thanks to u and so many members puring their valuable opinions
Originally Posted by nish_higher View Post
get this
What is aftermarket cooler and is it available in kolkata india...?
Links:
Yes gaming is not my primary objective.
One more Q: Q6600 vs E8200...which one is better...as what i could get is E8200 is 45nm; FSB1334 Mhz; etc( dont exactly know what it means but seems significantly better technology) but not in Q6600...
Intel DQ35JO(6K): Is it significantly better...???
DP35DP (5.5K) + E7200 (5K) +Gfx Card (3K to 44K , depends on you.):
So does it mean if i take DP35DP i have to compulsorily purcahse graphics card (and is it so expensive...???)
XFX 630i GF7150 mobo : is it better than other intel motherboards..???
THANKS PLEASE PROVIDE FURTHER INPUTS
Old 10-08-2008, 09:07 PM   #11 (permalink)
The Smaller Bang
Thumbs up Re: Intel D915GAV or Intel Core 2 Duo / Core 2 Quad...!!!
Depends on the context you are refering to. Its really cheap and VFM, and at the same time performs very well, and has Good Onboard Graphics. But it does not support dual channel RAM. Consider it as an option since it can get you a system that fulfills your needs perfectly, but is not heavy on the pocket.
All this depends on weather you REALLY want to spend the entire 12k-20k on the computer, or if you are satisfied by a lower priced rig which does the job and would be happy to keep the remaining money.
About Intel Motherboards:
What you need to be worried about is not just the company, but the CHIPSET. Abit IP35-E is a motherboard using Intel's own P35 chipset, the same one found in DP35DP board. Usually, intel boards from other brands like Biostar, Abit, ASUS, MSI, Gigabyte, etc are better than from intel itself.
And yes, today, most Intel chipset motherboards need you to shell out more money for performance, and cheaper ones often lack in something or the other. Only boards above 6K or 8K will give a very good performance. And for all these, you need to buy an external graphics card since few intel boards exist with onboard graphics. Also, intel's onboard graphics is rather low in performance. Intel boards are best and highly recommended for mainstream and above systems with an external graphics card and a good modern processor and also for overclocking.
Old 10-08-2008, 09:08 PM   #12 (permalink)
Violent serenity.
Psychosocial's Avatar
well let's clear it all.
First of all, you don't need to purchase a graphic card with any board. With that said, we all(i hope) suggest that you get a entry level graphic card so that you can easily run a new OS like Windows Vista OR Ubuntu 8.04.
I suggest you get a Quad Core as you are more into multi-tasking. Core 2 Duos (not Dual Cores are better at gaming because gaming works better with more frequency rather then more cores. As E8200 works at a better frequency then Q6600, it's better for gaming. Quad Cores reign supreme when it comes to multi-tasking with it's 4 cores.
Ok the combo you should get is - Intel Q6600 + Abit IP35e ,which should total to 14.5k and as i said, get a entry-level graphics card. I suggest a NVIDIA 8400GS for 2.8k. It should work fine for you.
Hope this helps
Psychosocial is offline
Old 10-08-2008, 09:21 PM   #13 (permalink)
The Smaller Bang
Hope this helps
sorry wrong again. You DO need a GPU on most boards since not all boards have onboard graphics.
8400GS for 2.8K would be the most dumb thing ever. Its too expensive. Better go for either 8600GT for 3K or HD3450 for 1.8K or 7100GS for 1K.
Might I ask WHY Abit IP35-E ? Its 2K more than XFX 630i. It does not have onboard graphics so you need to buy external card. Its main advantage, Overclocking, is not needed since he is not an overclocker and Q6600 OCs like a brick. He does not need dual channel memory or a good graphics card since he is NOT a gamer, rather, he is a multitasker. So XFX 630i would be the best bet for him. He neither needs to waste money nor will he loose out on the features he actually needs.
Old 10-08-2008, 09:42 PM   #14 (permalink)
Violent serenity.
Sorry for the misunderstandings made by me. MetalHeadGautham is right. But do get a dedicated GPU at all costs. 8600GT seems your best bet here.
Old 10-08-2008, 10:17 PM   #15 (permalink)
About Intel Motherboards:[/U]
Ok I am actually doing a heavy reading now on motherboard / chipset / etc...and first time i came to know that chipset and motherboard can be different. Actually out of hardware touch in last two years. now catching up with help of u guys.
One quick q though - Abit IP35 E uses Intel's P35 chipset the same found in DP35DP Board.
Then why get another motherboard from Abit rather than intel itself if they both use same chipset...???
Also see http://en.wikipedia.org/wiki/Universal_abit - ABit does not seem a reliable company
Now I got what u meant by Intel chipset Motherboards -- Motherboards of other companies with Intel chipset.
Which would be a good graphics card for rs 3000 to 4000 K...??
Boss i really want dual channel support (i have been using that for years and it makes RAM really fast)...
For normal movie watching and normal games - just in case - how much diff a graphics card makes...
# which is Intel's best Chipset and on which motherboard for Core 2 Quad...?
Last edited by sunandoghosh; 10-08-2008 at 10:24 PM. Reason: Automerged Doublepost
Old 10-08-2008, 10:35 PM   #16 (permalink)
Violent serenity.
A Graphic Card will help hugely by taking-off load of your CPU. You need Graphics Card to watch High-Def. content. Get a NVIDIA 8600GT for around 3.2k. Kingston 2GB DDR2 800MHz RAM (2x1GB). Abit is a good and reputed company. Quad Core is good for you. 630i chipset by NVIDIA is good for you. Wikipedia runs on user-submitted content and that means, dumb users and can post too. Hope, this clarifies it.
Old 10-08-2008, 10:57 PM   #17 (permalink)
Yes this helps a lot.
630i chipset by Nvidia...??? with which motherboard boss...???
As far as RAM goes whats highest Mhz in RAM available and is hynx or croissar better...???
One more q - do we get 2 gb single ram stick...and is any other motherboard and chipset capable of accomkodating 8 GB Ram...???
Sorry for asking too many questions but i am reading and want to have most basic doubts answered...
u guys really helping me a lot...kudossssssss
Old 10-08-2008, 11:11 PM   #18 (permalink)
The Smaller Bang
When Intel and another company both make motherboards with the same chipset, non intel made is prefered mainly because intel motherboards prevent overclocking. And they have NO customisations by default.
Abit is actually a good company. They were once unstoppable, then faded away, and recently returned back in style with the awssome IP35-E for mainstream and IP35-Pro for overclockers. But as per the latest reviews, they are again going behind, with Biostar, ASUS and MSI enterning the limelight for P45 chipset based boards.
A good 3k to 4k GPU would be 8600GT now, but I would advice you to wait and see what the 9500GT comes down to.
With 800MHz RAM, dual channel is going to give only 5% speed boost, and perhaps 10-15% when gaming. This is too trivial since the 800MHz RAMs are good enough for all tasks.
Actually, you NEED a graphics card (onboard or otherwise) if you want to see more than 8 colours on your monitor. For this, even onboard graphics will do. But the real help in things like video decoding depends on the card you are using.While most intel onboards like GMA 3100 which is found in Q35 and G31 motherboards suck, and can't play HD content and can't be used for low end gaming, onboards from nVidia and ATI rock. ATI Radeon HD1200, HD1250, HD3100, HD3200 and HD3300 rock and beat intel everywhere. nVidia GeForce 7050, 7100, 7150, 8100, 8200 and 8300 also rock as onboard graphics solutions. But ofcource, you should only be intrested in HD3xxx series and GF8xxx series if you need an onboard system that can actually play some GAMES as in Crysis, BioShock, etc, even though at low settings.
And even in dedicated graphics cards, the thing that makes lots of difference is the card itself. 7100GS won't offer any speed boosts over most onboard solutions, and is nothing more than a basic video processor. You need to think atleast as high as 8600GT or HD3650 if you need something which can play all games.
Any card from GeForce 8100 and above and Radeon HD3100 and above are capable of handling HD video decoding in MPEG, H.264 and VC-I formats. Lower end ones can't do it and hence your CPU is still taxed slightly.
There is no difference otherwise between an onboard card and a dedicated card in performance. Memory for onboard cards is often "shared", meaning used from the system RAM, while dedicated cards usually posess their own memory. Performance depends not on the place the card is installed (onboard or dedicated) but on its model.
Old 10-08-2008, 11:37 PM   #19 (permalink)
MetalheadGautham -- wow boss fundo conecpt...really makes lot more sense...
However much google explains but such explanations aid to real experince and practical implications...
I will dare to ask few more questions -- pls have patience with me --
1. SO it means these days in India Intel chipset P35 and P45 are quite popular and robust...?? ANy better chipsets near 5k to 6k or a little higher...
2. I think its better to go for dedicated graphics card as bcz it has its own ram so will not put burden on CPU ram...
I am gradually getting convinced on following config combo:
Intel Chipset p35 (ABIT based)...hope there is warranty help in india from abit
RAM 800 Mhz
Intel Core 2 Quad Q6600
and yes of course nvidia geforce Gt8600
i was also going through the link based on valuable inputs of all of u...
http://compare.intel.com/pcc/showcha...&culture=en-US
and i see that p45 supports 16gb ram and p35 supports 8gb...do we have such motherboards and ram chips available...??? anyone using...???
Last edited by sunandoghosh; 10-08-2008 at 11:47 PM. Reason: Automerged Doublepost
Old 10-08-2008, 11:49 PM   #20 (permalink)
The Smaller Bang
RAM 800 Mhz
1. yes. For intel Intel chipset is best and for AMD AMD chipset is best.
2. If you have 4GB RAM, you don't need to worry about that part.
Before thinking of getting a GPU or a high end motherboard, first state what you will actually DO with your system. Whats going to be its main work ?
Old 10-08-2008, 11:57 PM   #21 (permalink)
YES BOSS...my use of desktop will be varied...i will list out...
1. Running SAP IDES System
2. Playing Movies
3. NOT games so far
4. Opening 20 webpages and alternating them in between at times
5. Lot of dfs/word / excel files opened...
6. do lot of data copy transfer from one hard to another
7. try new softwares in system
etc etc
so i jsut wanted that speed should not be a limitation iff possible....
Old 11-08-2008, 12:32 AM   #22 (permalink)
The Smaller Bang
2. Playing Movies
3. NOT games so far
etc etc
Yup. Just what I expected. Abusive multitasking, but at the same time you don't run processor intensive apps. You are the perfect canditate for 4GB RAM, Core2Quad Q6600, but I don't think you need an 8600GT now. If you DO decide to game, get a graphics card THEN, not NOW, since things only become cheaper by age.
But have you considered an AMD rig instead ???
Old 11-08-2008, 01:54 AM   #23 (permalink)
abusive multitasking - he he he...may be u can say but i just dont want to be constrained by system in flexibility that i enjoy in keeping pages open...bcz i spent 12 hours daily on computers in my job and personal life from user point of view...but yes i agree not very judicious user...
Yes I have finally settled my mind based on all inputss here on -
4 GB RAM DDR 2
Nvidia Graphics Card assuggested may be later
BUT to be very honest still my heart has not been able to decide on Motherboard (with chipset)...I still am not sure which one to purchase...???????
No i have never thought about AMD as somehow Intel is deep rooted in me. And not sure or dont want to try new things like AMD unless needed....boss
Old 11-08-2008, 02:19 AM   #24 (permalink)
The Smaller Bang
4 GB RAM DDR 2
Abusive Multitasker is not an insult, rather, its a Title.
Now the problem with choosing a motherboard here is that you don't HAVE any value boards at the moment. All those P35 boards cost over 5.5K while the 630i might get old too soon (though it is perfectly enough for your needs). So you need to go for a higher end board, but its still not exactly *worth* the money you spend on it since the whole platform is going to become obsolete when September arrives with Intel Nehalem Core i7.
In such a situation, another thing you can do is to WAIT. Either wait for nVidia 730i to come sometime this month or the next month, or wait for Nehalem. The later is going to make you spend lots of money, so the former is the best wait you can do.
That was why I had suggested AMD. AMD CPUs are of good quality, but their main strength lies in their MOTHERBOARDS. A 4.5K AMD 780G motherboard is stronger than an 8.5K intel G35 motherboard. You can get the same configuration, but with more expansion slots and better graphics if you go for AMD. Phenom X4 9550 is available for Rs. 7,500 and a 780G board from MSI or Gigabyte for 4.5K. And from most reviews, it also can handle your tasks effectively, and at the same time it has the added advantage that the onboard graphics are good enough for ensuring that you don't need to buy another graphics card.
Old 11-08-2008, 02:20 AM   #25 (permalink)
PLS HELP IN SELECTING MOTHERBOARD WITH CHIPSET ONE LAST REQUEST...so that i can purchase the system asap...thanks
Old 11-08-2008, 02:44 AM   #26 (permalink)
The Smaller Bang
Do you think you will need more than 4GB RAM ? If NO, then XFX 630i is the board for you. If YES, bad luck. More thinking to do.
Old 11-08-2008, 03:34 AM   #27 (permalink)
Point Blanc
P45 is newest of the chipsets from intel.
Would never suggest an intel original motherboard if you are paying as much.
Besides Abit IP35E which is P35 based mobo there is MSI P45 Neo - F in 6.5K
Or better Asus mobos from Asus like P5Q in 8K or P5Q-Pro in 9K
Most of the quoted price are from ITWARES - Check this link
No need to wait for nahelam, only wait if you think there will be high price decrement, which I do not think as nahelam are bein released as ultra high end proccies like C2D Extreme And we are talking about general good proccies in affordable price range. Unless you think of spending 40K for a proccy. Besides this only Intel X58 chipset based mobos will support nahelam and none of the mobos and chipset being talked.
Check this link for intel original mobos
Besides this I will order the chipsets as P45>P43>G45>G43>P35>G35>G33 and did just a little addition to your comparision Intel chipset Comparision link
G series have onboard GFX unlike P series mobos, anyone here would recommend mobos other than Original Intel, mostly because other mobo makers use intel chipsets better and cost lesser and also you get better options.
For people like you and me GT8600 is more than enough and is more feasible in 3-3.5K price. So best option you got is MSI P45 Neo in 6.5K for mobo, you get P45 chipset based mobo in decent price or a little costlier from ASUS. Abit mobos are very good overclocker which I do not think you are. Proccy u can get Q6600 or Q9300 as 9450 would be much more costlier
acewin is offline
Old 11-08-2008, 04:02 AM   #28 (permalink)
The Smaller Bang
Nehalem 2.66GHz is expected to come for 15K in India if things go well. So it IS a thing to beware of. But yes, only X58 chipset is currently available for Nehalem.
Q6600 going to have more power than Q9300 since he is basically a multitasker, and hence the 2MB extra L2 cache helps while the extra clockspeed of Q9300 doesn't matter much since his apps aren't CPU intensive. Besides, the 2K price difference along with the fact that he is not an overclocker make Q6600 a sweet spot.
Since he is not a gamer, even 8600GT is not needed by him and onboard GFX will do.
Q6600 doesn't need more than 4GB RAM, and he isn't a gamer or an overclocker. Hence 630i will be sufficient. P45 is not needed unless he gets Q9300 CPU and decides to overclock it for performance, which he is not doing.
So,
either:
XFX 630i Ultra - 3.5K
C2Q Q6600 - 9K
total 12.5K.
OR:
MSI P45 Neo - 6.5K
C1Q Q9300 - 11K
NV 8600GT - 3.5K
total 21K.
Old 11-08-2008, 06:40 AM   #29 (permalink)
Point Blanc
nehalem 2.66 quoted price by intel is 284$, and if you count it then yeah it would come around 15K, but Indian prices always comes out to be one and a half times than US prices.
Well 8600Gt is not real necessity he can go for 8400 GS also but I will suggest newer chipset based mobo for he performance he would want. XFX 630i Ultra is good onboard GFX mobo but P45 or P35 chipset mobos would be better for him, because the are more performance oriented chipset.
acewin is offline
Old 11-08-2008, 07:06 AM   #30 (permalink)
The Smaller Bang
Performance oriented ? Definte the term in this context please.
When will Intel Core 2 Quad Q9450 be available?? confused Hardware Q&A 10 04-04-2008 06:38 PM
Intel Core 2 Quad 2.4 GHz at $266 on July 22nd Edburg Technology News 4 16-05-2007 02:10 PM
Intel Quad Processor VS Dual Core Pravas Hardware Q&A 13 15-03-2007 12:54 PM
Intel Core 2 Quad reviews hit the net naveen_reloaded Technology News 7 05-11-2006 11:12 PM
Intel ships first quad-core Core 2 Extreme QX6700 sabret00the Technology News 4 15-10-2006 12:14 PM
