Old 09-08-2008, 11:05 PM   #1 (permalink)
The Sexy Beast
Default DMI Pool Data not verifying
i've overclocked my e7200 to 3.57Ghz on Abit IP35-e but most times it does not verify the dmi pool data and so it shows 2.53Ghz in windows.how can i solve this or am i getting the same performance at 2.53Ghz when i've actually set it to 3.57
ratedrsuperstar is offline
Old 10-08-2008, 12:28 AM   #2 (permalink)
Default Re: DMI Pool Data not verifying
that you as an overclocker should know the difference in speed and there are tools to check it out...
but you could try resetting it to default and then overclock from scratch again...
realdan is offline
Old 10-08-2008, 01:42 PM   #3 (permalink)
The Sexy Beast
ok will try seeing the speed difference
Old 13-08-2008, 09:01 PM   #4 (permalink)
The Sexy Beast
the speed difference is big.about 15 fps for a DVDrip movie in Vdub and about 7000MOPS in Sisoft sandra.even my RAM bandwidth gets reduced by 2GB/s.
thankfully the problem isn't there anymore it boots with 3.57GHz always.but i rolled back my bios to an earlier version.could that have been a prob
Love Struck Emotion in Yahoo Pool Games! ( V'day ) Rockstar11 Chit-Chat 1 14-02-2008 04:08 PM
What Softwares/techniques data recovery professional use to recover data from HDD ? CadCrazy Software Q&A 1 10-08-2007 10:01 AM
Broadband verifying password....Is it a virus?? Dongay Rajasekhar Panda Software Q&A 5 11-10-2006 03:13 PM
