Old 09-08-2008, 08:37 PM   #1 (permalink)
vishald's Avatar
Exclamation Not able to restart with new motherboard
I recently purchased a new intel 865 motherboard which does not restart.
When pressed restart button directly or when I restart from windows it shuts the computer and gives a continuous long beep.
I am able to shut down the computer from windows without any problems.
I have to shut down the computer as I am not able to restart.
Pc configuration is p4 2.4ghz 512 mb ddr 1 ram esonic 865 motherboard.
Any suggestions?
Vishal
vishald is offline
Old 09-08-2008, 08:46 PM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: Not able to restart with new motherboard
check the motherboard's manual, and look for the reason why its beeping, and solve your problem......
if not then check the website for beep codes....
Sooraj_digit is offline
Old 09-08-2008, 09:35 PM   #3 (permalink)
vishald's Avatar
Question Re: Not able to restart with new motherboard
I have already checked for beep codes. There is information regarding normal beep code.
The computer works just fine. Only restarting problem.
We get such a long beep only when key board is absent. Tried changing keyboards also but in vain.
Vishal
vishald is offline
Old 09-08-2008, 09:38 PM   #4 (permalink)
VJ
vijayb's Avatar
Long beep code is signal of BAD RAM
vijayb is offline
Old 09-08-2008, 09:42 PM   #5 (permalink)
where did u get a intel 865 mobo now a days ? just curious last time i checked 3 months ago vendors told me intel has discontinued the 864 chipset
imgame2 is offline
Old 09-08-2008, 10:09 PM   #6 (permalink)
vishald's Avatar
Unhappy Re: Not able to restart with new motherboard
Already changed the ram and checked. Still does not work with other rams.
Vishal
vishald is offline
Help me restart pbm aravind.gslv QnA (read only) 1 06-05-2008 01:30 AM
again restart rounit Software Q&A 5 13-07-2007 05:25 PM
PC does not restart spp_itim Hardware Q&A 5 17-01-2007 10:21 AM
PC restart CyCo QnA (read only) 18 04-10-2006 01:56 PM
Restart my pc. sonmani Hardware Q&A 6 21-06-2006 09:24 PM
