Old 09-08-2008, 03:01 PM   #1 (permalink)
Unhappy DG965RY supports E7200??
Hi friends help me out.Please let me know does my DR965RY board supports E7200 Processor.I am not able to figure out because maximum FSB supported by this board is 1066 and the same FSB E7200 has.So is it possible to run E7200 or I have to change board for new processor upgrade?
iHATEdigit is offline
Old 09-08-2008, 11:25 PM   #2 (permalink)
Default Re: DG965RY supports E7200??
you have to go to http://www.intel.com and find out your motherboard model no.. from there...and then go to that model and find from the site whether it is supported or not
realdan is offline
Old 10-08-2008, 11:23 AM   #3 (permalink)
Tux Fan
shaunak's Avatar
Nope.
Go here: http://processormatch.intel.com/Comp...rdname=dg965ry
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 10-08-2008, 11:39 AM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I think it should... if the FSBs match...
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 10-08-2008, 11:46 AM   #5 (permalink)
Google Bot
Pathik's Avatar
Nope. It doesn't. Get a G33 or P35+
Pathik is offline
Old 10-08-2008, 11:49 AM   #6 (permalink)
The Smaller Bang
how ?
Old 10-08-2008, 01:46 PM   #7 (permalink)
Google Bot
Pathik's Avatar
Cos it doesn't work with the newer 45 nm proccys? AFAICR!
Pathik is offline
Old 10-08-2008, 02:43 PM   #8 (permalink)
Point Blanc
pathik is right check the intel link shaunk has given
acewin is offline
Old 10-08-2008, 04:33 PM   #9 (permalink)
The Smaller Bang
I remember reading online about some bios hacks... guess they might void warranty...
E7200 temp issue Fahd.Malik Hardware Q&A 6 08-08-2008 10:51 PM
Overclocking E7200 and OCZ Ram on IP35-e ratedrsuperstar Overclocking 3 22-07-2008 10:19 AM
Suggest Motherboard for Core2Duo E7200 blackbird Hardware Q&A 5 20-07-2008 01:59 AM
gtalk now supports AIM like MSN supports Yahoo msngr iMav Random News 6 18-03-2008 10:35 PM
Suggest me a nVidia 4 C2D & DG965RY Innovator Gamerz 5 13-11-2006 10:55 PM
